P0328 - Knock Sensor code
Old Sep 9, 2018 | 03:59 PM
J Free's Avatar
J Free
Yesterday driving, my engine warning light came on (yellow). After a few minutes it went off. I pulled the code and got P0328 - Knock Sensor 1 Circuit High (Bank 1 or Single Sensor). It looks like some labor is involved with getting to the sensor even though the part is not hugely expensive. Can I easily test to confirm failure, do I look for some other problem causing the fault, do I just get one and replace?
Old Feb 8, 2022 | 11:02 AM
Denim763's Avatar
Denim763
I am also experiencing the same code (P0328) what did you end up doing?
Old Feb 11, 2022 | 04:49 PM
Briscoec's Avatar
Briscoec
What yr is your car?
If it was a new car, maybe nothing. I had an 07 justa that kept coding knock sensor.
During a rebuild I discovered a chunk broken off 2 pistons. The pieces were still riding inside rings. Yikes
Old Feb 11, 2022 | 04:50 PM
Briscoec's Avatar
Briscoec
Old Feb 15, 2022 | 12:15 PM
schovil69's Avatar
schovil69
I'm will be putting my '08 MCS up on a lift to access the knock sensor located on the rear of the block from below. I have an occasional knock sensor code popping up. First thought is a faulty sensor and since this one is inexpensive its an easy way to eliminate it as a possibility.
Brandon Fluharty
Oct 12, 2021 11:31 PM
gatorsr53
Sep 8, 2015 03:30 PM
jaytech
May 27, 2009 09:43 AM
jrprich
Sep 6, 2008 06:46 PM
m32
Oct 8, 2007 12:35 PM
