Suspension 1 inch lowering
Old Sep 7, 2018 | 10:00 AM
Kevinp_27's Avatar
Kevinp_27
1 inch lowering
Looking to lower my r56s 1 inch. Only 1 inch since I live in San Francisco and the roads are horrible. I read about NM springs but they are slightly too low for me. Do any of you guys have knowledge about which springs give a 1-inch drop? thanks
Old Sep 7, 2018 | 01:31 PM
Richieb0y28's Avatar
Richieb0y28
Alta has H&R springs: https://altaperformance.com/ag-15596...uspension.html
Says the drop will be about 1.4"
Old Sep 7, 2018 | 02:03 PM
LostbutFound's Avatar
LostbutFound
ECS has some JCW springs that advertise .98 inch drop.
Old Sep 7, 2018 | 02:10 PM
R56 MINI Cooper S here:
https://www.ecstuning.com/Mini-2007-...nsion/Springs/
Godspeed are about 1" drop. Swift are around .75-1" , madness is close to that.
JCW are about 10mm lower than stock Cooper S
Old Sep 7, 2018 | 02:18 PM
LostbutFound
These are the ones I was referring to. They say they are for both S and JCW.
https://www.ecstuning.com/Mini-2013-Cooper_Coupe-R58-Cooper_S-Coupe-N18B16A/
edit... just noticed that you have a 2007 and these don't fit. Sorry for the distraction.
Old Sep 7, 2018 | 02:41 PM
They are known in the MINI world as a 10mm drop and are called in to order the right ones with your VIN.
We will update the description. Thanks
Old Sep 7, 2018 | 06:59 PM
mbwicz's Avatar
mbwicz
I ran TSW springs (purchased from Way Motor Works) for several years and was happy with them. They are about 3/4" drop.
Even with a moderate drop, you may want to think about getting shocks. My car rode better and was more controlled with koni yellows than the stock shocks.
Here is a nice setup on the marketplace, if you have $$ to spend now. JCW red springs, Bilstein sport shocks, and new strut mounts to increase front camber a bit.
https://www.northamericanmotoring.co...ed-camber.html
Have fun,
Mike
Old Oct 30, 2018 | 11:19 AM
KCLARK's Avatar
KCLARK
For a minimal drop there is very few to pick from and looks like they are all mentioned in this thread.
Question is when picking out the bunch, what are the spring rates, because they are all different and can provide a soft or very firm ride depending on which springs you pick.
Old Oct 30, 2018 | 02:21 PM
damnitdanny's Avatar
damnitdanny
https://www.waymotorworks.com/megan-racing-r56-lowering-springs.html and https://www.waymotorworks.com/tsw-mini-performance-springs-r56-r55-r57.html
says for the Megan's .5" front - .75"rear and for the TSW's 1" front - .75" rear
dj.papazian
Aug 19, 2010 02:40 PM
Finner
Jan 24, 2009 07:35 AM
PoktRokt
Nov 26, 2008 10:30 AM
meanboy
Tires, Wheels, & Brakes
Sep 6, 2005 11:21 AM
