Shudder
Old Sep 6, 2018 | 04:07 PM
Sstrickstein's Avatar
Sstrickstein
Shudder
I have a 2007 Mini Cooper S with Coil Overs, upgraded sway bar and rebuilt engine, clutch and just about everything else that has come up. When I take off in "NON" sport mode I get a slight shudder at first. Sport mode on no shudder. Ive just inspected the entire suspension in the front and the only thing I can say is my swing arm bushings are original. They don't seem to be wacked. But asking around. This looks like a drop the exhaust and subframe job so I want to be sure before I dive in.
Old Sep 7, 2018 | 03:41 PM
oldbrokenwind's Avatar
oldbrokenwind
"Swing arm bushings"? If you're referring to the lower engine mount, it's one of the easiest mods to install. Maybe a floor jack under the pan to support the engine while you change it, but no exhaust or sub frame to mess with. If you're referring to the wheel mounted steering bushings, these too are changeable without exhaust or subframe interference. If it's the front sway bar bushings in question, I can't help --- never messed with it. Have you checked NewTIS.info for their procedure?
maddog
May 8, 2010 03:33 PM
cooperkid
Feb 6, 2007 08:01 PM
FredBRG
Nov 27, 2006 05:17 PM
skillet
Aug 11, 2006 08:47 AM
boognish
Nov 20, 2004 01:18 PM
