Replacing Ignition Coil...Bosch Performance Ignition Coil?
Old Sep 4, 2018 | 05:36 PM
General USA's Avatar
General USA
Hey Yall,
I am doing a tune up and just going to replace the ignition coils. M7 Speed advertises a Bosch Performance Ignition Coil set of 4 for $189. Looking at the pictures they have one of the box (below) and have blacked out on purpose the Bosch part number? I am looking at other Bosch coils that range from $26 to $30 max a piece. Is there such a thing as a PERFORMANCE ignition coil by Bosch, or is the price just jacked up and there is only one coil Bosch produces for 2008 Clubman S?
Old Sep 4, 2018 | 08:48 PM
EdsNotHere's Avatar
EdsNotHere
I use the Delphi ones off Amazon and at 20lbs of boost not a single issue. Mine had Delphi OEM
Old Sep 4, 2018 | 08:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Go with the original MINI ones. We have done a lot of testing and find the aftermarket coils to either fail quickly, or they don't put out as much voltage as the originals and you actually end up with a weaker spark. Audi guys have had this issue for years. So it's worth spending the extra to know you are getting a quality part and they have a 2yr warranty.
https://www.waymotorworks.com/direct...9-r60-r61.html
Old Sep 19, 2018 | 03:59 AM
tsa1's Avatar
tsa1
Did you compare the OEM delphis to the Amazon Delphis? I'm looking to replace all of them and $25 a pop sounds better than $68-70 each.
Thanks in Advance.
Old Sep 19, 2018 | 06:00 AM
chrunck's Avatar
chrunck
I also recommend using OEM coils. I was having some hesitation and what felt like misfires (no codes) with Bosch coils off of Amazon, and replacing them with OEM coils seems to have fixed it. I didn't start having trouble until I moved from FL to NM, so YMMV.
Someone in a thread somewhere else said you can order directly from Delphi and get the same coils as the MINI ones but without the MINI logo on them.
Old Oct 8, 2018 | 06:18 AM
Staggs's Avatar
Staggs
Are you comparing to ones off Amazon, or the High Performance set from Bosch? Looking at the high-performance ones myself, but if people aren't having success with them I can stick with OEM. My R56S has a few upgrades, but I haven't had to replace the coils/plugs since then.
Old Oct 8, 2018 | 03:57 PM
MrGrumpy's Avatar
MrGrumpy
From experience, I prefer to use the OEM coils. I bought a set of “performance “ upgrade coils for my ‘12 R60 and immediately had major misfire issues. Went back to the factory coils and it ran perfectly. Even with a stage 3 tune running 22 psi, my Mini runs best with OEM coils.
Mine came from the factory with Delphi coils, but I believe that they also used Bosch some production runs.
That may have been me mentioning buying them on Amazon. You want to make sure you get the correct ones. What I did was look them up on realOEM.com to get the correct part # and manufacturer. You can then get that same coil from Delphi or Bosch on Amazon for quite a bit less. The ones I ordered came right from Delphi, and are exactly the same as the ones I took off except that the MINI logo is absent. That logo is pricey. For $120, I had 4 new OEM coils on my doorstep in 2 days and saved a chunk of change to boot.
Old Jun 14, 2021 | 09:34 AM
Clockwork's Avatar
Clockwork
I replaced my original Delphis with $20 Bosch units (0221504800) from RockAuto.com and so far I'm happy with them and prefer that these ones are fully rubber coated, so no rusty looking coils after a while. Having said that, The Delphi coils are only $30 each so I could have gone with them but the rubber coating spoke to me after seeing my delphi's were rusty adn I live in the least humid place on earth, I swear.
Old Aug 17, 2021 | 11:38 AM
HarryEngine's Avatar
HarryEngine
Hi guys. Perhaps the ignition coil is indeed overrated. Most likely it is. I recommend checking everything before starting the car. I use a trusted site Chevy 6.6 Gas Performance Parts where I can find out the price and quality of all parts.
Old Jan 12, 2022 | 04:58 PM
stiksandstones's Avatar
stiksandstones
My mini has DELPHI's, and on realOEM the part number is Delphi as well...
ridinDirty
May 14, 2021 07:15 PM
Eric Campbell
35
Oct 27, 2020 08:31 PM
Camaro108
Apr 23, 2014 06:03 PM
xman11
Electrical
Jul 12, 2010 02:03 PM
scolburn79
Mar 11, 2008 11:10 AM
