02 Mini S - Automatic Trans (Stall/sudden downshifting)
Old Aug 24, 2018 | 07:26 AM
Weebo134's Avatar
Weebo134
Good Morning,
I am new to this forum and to Mini's. I just picked up a very clean 02 Mini S and it has a couple of issues that I am trying to sort out. The friend that I got the car from mentioned that it had, on occasion, "stalled" at a red light or stop sign, but would easily restart. Also, when I test drove the car, when releasing the gas pedal (on a down hill) the car suddenly began to down shift rapidly through the gears, all the way to 1st. after returning to the house, I went out for a second test drive and it never hesitated once, DROVE PERFECT!. I then returned home and went for a third drive. On this drive it rapidly downshifted, again on a down hill. all three test were done within one hour. I took it for a test drive yesterday and it had a new issue. after pilling out of the driveway, and attempting to go up the hill, I had the pedal to the floor and I didn't seem to get full throttle (or the trans didn't downshift). it did this a couple of times on this test drive.
I have been doing some online research and found several articles, so I have been making a list of "possible causes/solutions".
1) Clear the adaptations and relearn the transmission
2) Accelerator Pedal Position Sensor
3) Down shift solenoid
4) Oil Extreme Additive
I don't know if I'm right or not, but I am leaning toward the first 2. I checked codes and the only ones showing are O2 sensor codes.
any suggestions or assistance would be greatly appreciated.
Thanks,
Glen Weaver
Maryville, TN
Old Aug 24, 2018 | 08:02 AM
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
Glen...How many miles are on the car. MINI says that the trans fluid is 'lifetime' and I think they defined' lifetime' as the life of the warranty. I have a 2005 R52 s and I plan to change the trans fluid when it reaches 50,000miles. I would put changing the trans oil between 1 and 2.
sparkyj
Nov 23, 2015 04:39 AM
mjwill97
Jun 17, 2013 09:04 PM
ronmichael
Jun 1, 2009 10:09 PM
NJ Clubman
Nov 11, 2008 10:38 AM
multipurpose
Apr 7, 2003 06:14 AM
