'12 R60 about to impact crude oil prices
Old Aug 22, 2018 | 10:11 AM
CG Matt's Avatar
CG Matt
Hello - I have just developed a strange issue....
Car has been fine since new... One day last week before a long trip - I changed the oil...
Left the house - went a mile to stop sign... oil light flickered for a second and I figured "whatever" I just did an oil change, maybe it was a bubble (that hasn't come on since)
I gassed up by the highway - got on the highway... And laid down a blue fog bank for 60 yards or so....... (said to myself WT#) and started to coast...... yellow engine light came on - stumbled a bit - limped to home from there....
There was that one time I "slightly" overfilled the oil - 2 changes ago - so when reading about something similar - all signs pointed to replacing the valve cover (needs a new PCV valve I thought). Once that was replaced - I checked the oil level and it was down almost 2 quarts from the change (2 quarts in about 8 miles of driving!!). The plugs looked bad - so I sprang for new ones.... Started great, ran great for 50 yards and laid down a puff once the turbo pressure built up. It suddenly dawned on me that I have 2 quarts of oil (maybe) from the turbo inlet all the way to the tailpipe and more work was necessary....
I took the car apart and cleaned out the intercooler and all the pipes (there was at least half a quart in the intercooler....). Ran it yesterday for 50 miles and no issues at all.....
Today I get in and the yellow engine light is on from startup rough idle - power seems fine once it's moving but that light stays on.... I checked the oil level and it's going down again....
So my thinking now is I have a bad oil filter.... All this started after an oil change.... But my question is - What would cause that much oil to enter the inlet "system". Any thoughts?
Old Aug 25, 2018 | 10:31 AM
bmwr606's Avatar
bmwr606
did you damage the bypass or drainback valves when you changed the filter?
Old Aug 25, 2018 | 12:38 PM
CG Matt's Avatar
CG Matt
Thanks so much for the response!
I'd say its possible(?)
I put another oil filter in yesterday. The one I took out seemed 1/2 longer than the new one - and was warped on the end where it would touch one of those valves.
It's running/starting better - and the half power light isn't coming on at all now. But I'm still losing oil someplace into the induction...
Would blocking those cause a pressure spike into the turbo seals?
Old Aug 25, 2018 | 01:09 PM
bmwr606's Avatar
bmwr606
can't help you with that question, just know from reading posts for 6+ years that bad things happen when those valves get broken
Old Aug 25, 2018 | 04:41 PM
MrGrumpy's Avatar
MrGrumpy
Good luck. Post what you find out.
ScottRiqui
11
May 29, 2007 11:09 PM
Koopah
Tires, Wheels, & Brakes
Apr 16, 2005 12:39 PM
D.D.
Jan 17, 2005 09:53 PM
PJ
Jan 7, 2003 05:17 PM
