Tire pressures on and off the car.
Old Nov 12, 2004 | 02:42 PM
biggripper's Avatar
biggripper
If you check a tire pressure of a tire/wheel that is off of a car will it be less than if it was on a car (supporting the cars weight)?
Sorry for the dumb question but I have never had a second set of wheels/tires before. This is a new one for me.
Old Nov 12, 2004 | 03:04 PM
satay-ayam's Avatar
satay-ayam
It won't change a whole lot, probably not enough to measure.
If you want to do an experiment, you don't even have to remove the wheel from the car. Just jack the car up so the wheel is off the ground - there is no force on the tire then. Measure it "off the ground" and "on the ground" and see if you can detect a difference.
Old Nov 12, 2004 | 04:33 PM
kenchan's Avatar
kenchan
The difference is usually less than half a psi on compact cars...so unless
you have a digital pressure guage, you won't be able to tell that much.
TJANK
Aug 24, 2015 06:11 PM
JamJam43087
Aug 16, 2015 02:02 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
