Changing spark plugs
Old Jul 21, 2018 | 11:17 AM
alexh1's Avatar
alexh1
Hi,
2009 Base.
I have another car with aluminum heads and as the car got older I thought for sure I pulled out the threads one time. Since then I learned not to use anti-seize (or very little) and on that car at least I spray some penetrant into the holes before removing the plugs. I work them out with a back and forth motion because at least when I used the anti-seize there was lots of friction if I just pulled them out at one go.
I don't see that this is an issue with the mini but just want to make sure as I know many have turned a $200 repair into thousands because of stripped heads.
I got the NGK BKR6EQUP plugs and install using vacuum hose attached to the plug electrode. Torque 15-19 ft lbs. I don't see any gap info so I assume factory gap OK.
2004JBMINI
Jul 2, 2012 12:02 PM
perucho
Feb 20, 2011 09:50 AM
Archanum
Jun 17, 2008 01:40 PM
Mr. D
Jun 2, 2007 10:13 AM
