R56 Amber Tails for White, doesn't work right?
Old Jul 14, 2018 | 08:17 PM
rob_lewis's Avatar
rob_lewis
Hit the local pick and pull today and one of the things I was looking for was a new passenger tail light for my '12 S.
Found an earlier 2nd gen with Amber turn signals instead of the clear ones mine had, so I snagged both of them because I liked the look better.
Plugged in the first one, but the amber turn signal is on when the lights are on.
Was there a wiring difference between the model years and/or between the clear turn signals vs. the amber ones?
I, mistakenly, assumed the wiring was the same.
-Rob
Old Jul 16, 2018 | 09:06 PM
EdsNotHere's Avatar
EdsNotHere
The bulb mounting board should be the same just swap them and should work
Old Mar 29, 2025 | 11:19 PM
dagnabbit7767's Avatar
dagnabbit7767
did you ever figure this out? i just bought a pre-facelift pair of tail lights and i’m having the same problem. it’s like everything’s wired differently
Old Mar 31, 2025 | 08:06 AM
z168's Avatar
z168
Did you see the response ^ Are the bulb mounting boards different? Perhaps just swap them out
Old Mar 31, 2025 | 06:31 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The pre-LCI tail lights are wired differently from the LCI tail lights. They are not directly interchangeable.
David MacNeill
Feb 3, 2022 11:31 AM
mbwicz
Jan 6, 2019 03:27 PM
milktree
11
Dec 2, 2011 03:43 PM
Hellion
Jun 6, 2008 01:41 PM
tenniswack
Nov 30, 2006 07:40 AM
