R52 Removing Dash - What to repair?
Old Jul 9, 2018 | 07:50 AM
Sean Medley's Avatar
Sean Medley
My Mini is in the shop getting the blower motor replaced, necessitating the removal of the entire dash. Since this process is like 8 hours of labor, I am wondering, w hat else should I have them check while it is torn apart? I would hate to go through this again for a part that would make sense to replace now!
Old Jul 9, 2018 | 08:58 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
The key is moving parts like motors. I cannot think of any, except if you have auto climate control which I assume has a lot of vacuum actuators, have them check the condition of the rubber vacuum hoses. Rubber vacuum hoses are a mixed bag in quality. Typically German are excellent. UK made, think Lucas electrical quality.
Old Jul 9, 2018 | 09:15 AM
Sean Medley
Thanks for the info. I took a look at a pic from a dash removed and could basically see wires, hoses, air ducts, and the dang blower, smack dab in the middle in the back. I know the rest of the mechanical items from the cooling/heating system are accessible as I replaced them last year!
Old Jul 9, 2018 | 11:31 AM
H_C's Avatar
H_C
You may want to replace the padding on the rear of the dash.
Chances are, the foam is falling apart. Replacing it will stop the dash from squeaking.
Old Jul 12, 2018 | 07:06 AM
I took mine all off and used the soft side of the velcro tape all over the underside, MINI dealerships do the same thing. Just watch around the airbag system.
alistaircookie
Sep 2, 2014 01:39 AM
XrayDeltaOne
Jul 7, 2006 08:37 PM
MiniS AZ
Apr 22, 2006 01:31 PM
n3nyongmini
Nov 10, 2005 05:41 AM
meanboy
Aug 6, 2005 01:21 AM
