Suspension r55/r53 rear sway bar question
Old Jul 7, 2018 | 06:57 AM
bump32's Avatar
bump32
I've found a used 22mm sway bar that was taken out of a 2010 clubman S. It comes with the brackets and rubber bushings. My research on the parts finder shows that the r55 and the r53 both used the same stock 17mm rear sway bar.
Am I correct that a sway bar out of a 2010 Clubman will fit in a 2006 MCS??? Am I going to have any issues with the end links or the bolt pattern to the frame?
Thanks in advance.
Part number:
33556754819
Stabilizer, rear
D=17MM
To:-
Weight:2.690 kg
Price:$129.55
Supersedes:
33551507997(12/18/2000 — 03/28/2001)
Part 33556754819 was found on the following vehicles:https://www.realoem.com/bmw/enUS/part?id=ZG33-USA-11-2010-R55N-Mini-Cooper_S&mg=33&sg=30&diagId=33_1692&q=33556754819
Old Jul 7, 2018 | 08:56 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The R53 and R55 do use the same sway bar.
The bar you found would have to be an aftermarket to be a 22mm as 18.5 would have been the largest ever offered from the factory.
Old Jul 7, 2018 | 09:15 AM
bump32's Avatar
bump32
Thanks.
*Yes the 22mm sway bar is aftermarket... I was just making sure the original sway bars that both cars had when stock, were the same.
And BTW... the ATI super damper kit I bought from you guys a couple weeks ago arrived quickly and installed easily. Thanks
Old Jul 7, 2018 | 10:51 AM
Fly'n Brick's Avatar
Fly'n Brick
If that RSB is adjustable and you set it at the stiffest setting, don't sneeze on the steering wheel or you'll wind up in Omaha. You will have and entirely different handling MINI...and you'll love it.
Old Jul 7, 2018 | 04:09 PM
bump32's Avatar
bump32
A few more details on what I'm thinking.... I will gladly take all input.
I have a 19mm H&R rear sway bar currently. It has two adjustments of which I started in the softest and moved it to the the stiffest about a month ago before a day at the track. Going to the stiffer setting on the 19mm felt good but (no expert here) I feel like it needs more??? Maybe I'm wrong but the plan is to put the Madness 22mm (three adjustments) in on the weakest setting and compare. If it's good, I'm good with room to grow. If it's to much, I'll put the 19mm back in and keep the 22mm till I have more suspension work done. I got a great deal on it so I feel like it's worth a shot.
Old Jul 7, 2018 | 08:34 PM
WayMotorWorks
Vendor
Your correct in thinking you want more than a 19mm. We've installed over 1000 sway bars and most of them have been the larger bar.
Go with one of our Hsport Comp rear sway bars and put it on the middle setting it is ideal. It will weight only 5.5 lbs so much lighter than a solid 22mm bar, and the bushings on these bars are the best as they actually hold the grease so you don't get noises.
https://www.waymotorworks.com/h-spor...-sway-bar.html
Old Jul 7, 2018 | 09:22 PM
Fly'n Brick
Just for your idle curiosity, here's a comparison from a different brand. The figures may not be the same but will at least give you an idea of what you are dealing with with the two bars you are talking about.
OEM Stock Bar (17mm ) Baseline For Rate / Effective Rate =117 LBS/IN
ALTA 19mm Bar Setting #1 115% Higher Rate / Effective Rate =135 LBS/IN
ALTA 19mm Bar Setting #2 140% Higher Rate / Effective Rate =165 LBS/IN
ALTA 19mm Bar Setting #3 177% Higher Rate / Effective Rate =208 LBS/IN
ALTA 22mm Bar Setting #1 213% Higher Rate / Effective Rate =250 LBS/IN
ALTA 22mm Bar Setting #2 260% Higher Rate / Effective Rate =305 LBS/IN
ALTA 22mm Bar Setting #3 329% Higher Rate / Effective Rate =386 LBS/IN
Old Jul 8, 2018 | 07:50 AM
bump32's Avatar
bump32
Bought the used 22mm Sway Bar with Whiteline Adj. links for $100 last night so me and the Mini are going for it.
Thanks (WAY MOTOR WORKS & Fly'n Brick) for all the info.... I'll try and post my thoughts after I install it.
Old Jul 8, 2018 | 10:09 AM
Fly'n Brick
Somethng I like to do when people start asking ignorant questions about these cars is to invite them to grasp the rear fender well on their appliance and lift. It always comes up a little. Then, do the same on my car. It don't budge. The look on their face is worth the price of admission.
silviahrc
R55 :: Clubman Talk (2008+)
Mar 31, 2017 06:41 AM
silviahrc
Mar 23, 2017 06:27 PM
vodka
Suspension
24
Feb 16, 2009 09:40 AM
