fan locked on
Old Nov 8, 2004 | 03:44 PM
jlm's Avatar
jlm
fan locked on
after replacing my clutch (personally) and putting my rig back on the road, my radiator fan now comes on about 10 seconds after starting the engine (hot or cold) and remains on!@#@ until you turn off the key.
AC on or off makes no change; I monitored the ECU reading of the coolant temp and it was normal. I also disconnected the battery ground, grounded the hot lead for a few seconds, and hooked 'er back up, but the problem remains.
any thoughts?
Old Nov 8, 2004 | 04:14 PM
moonman9j9's Avatar
moonman9j9
The only thing I can think of is that maybe the power to the fan was somehow wired incorrectly. What I mean is, maybe the power to the fan is constant where it should be controlled by the ECU.
Is that possible?
Old Nov 8, 2004 | 04:28 PM
Ryephile's Avatar
Ryephile
shot in the dark [pre Bentley schematic review]
Relay stuck open? (aka: where's that hammer?)
Old Nov 8, 2004 | 08:27 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Check to make sure that the a/c pressure sensor isnt disconnected, or it's wiring damaged or grounded. Also make sure that the fan speed control harness is connected properly (there is a relay mounted to the fan shroud that controls the fan's two speeds, it has smaller wires running to it).
Other than that, I cant think of any other issue causing it offhand, since you say the temp reads properly.
monkiboy
Oct 16, 2015 09:58 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
