Mini/MINI BUILDS Showcase your Build Talents.
K24 swap into R53
Old Jun 27, 2018 | 07:04 PM
Kr4nG's Avatar
Kr4nG
K24 swap into R53
I have wanted to do this for such a long time. Ever since I sold my fully built integra. Not going to go into to much detail about it but lets just say it was flawless.
What I have now is a 2006 mini cooper S
Interior: black interior and black leather seats, gps, harmon kardon audio, some gauges.
Exterior: chili red with JCW front grill and front bumper: real JCW gen 1 front brakes, 16x8 rota grid v wheels
Performance: JCW injectors, Megan header, Milltek exhaust, 17% pulley, maybe jcw tune
New Engine:
2007 acura tsx motor
2.4 liter
rsx type s water pump
rsx type s oil cooler
skunk 2 style intake manifold
70mm throttle body
rsx type s VTC gear
rsx type s oil pump
engine management K-pro
Transmission: civic type r ep3 6 speed with LSD
As you may know that no one makes mounts for this swap so I bought 2 sets of aftermarket mounts. 1st is for 06-11 civic si and 2nd is for 94-01 integra kswap. I used the trans mount from the integra kit and the motor mount from the civic kit. I do not have a a/c tig welder. Ive been using my 100$ welder this whole time and I like it. Im very used it it. But I wish I had a tig.
The motor does not fit. A few things need to happen. Both rails need to be notched out. As well as the subframe but only on the drivers side.
Driver axle is from integra. The integra left and right axle as exactly the same, even if you filip the inner cups. The integras outer hub fits real good onto the coopers bearing but if you use the rsx base axle the outer hubs wont fit. The ring that is on it hits the bearing seal. You can use the integra outers and swap the rsx axle becasue its longer. I will use the rsx base axle on the passenger side with the integra outer cup but leave the stock integra axle alone for the driver side.
Motor is in but not fully attached
Trans mount I made
Mounts
Not much clearance left
Rail is welded back up. Just the mount
Mount is welded to 1/4 inch steel plate.
Last piece 3/16 steel
A lot of extra metal left over. I bought 2 sheets of 3/16 plate 8x12 and 2 sheets of 1/4 8x12
I used 1 sheet of 3/16 plate and half of the other. And a little of the 1/4 inch steel plate. I have the other 1/4 left not used.
So as it sits now with both rails in primer ready for seam sealer and paint. I have to make the 3rd mount next
Old Jun 27, 2018 | 09:04 PM
Jack & Coke's Avatar
Jack & Coke
Bad ***! Incredible amount of work and determination to get this stuff done. keep the thread updated.!
Old Jun 28, 2018 | 03:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Very cool! I like seeing different ideas come to life.
Old Jun 28, 2018 | 03:59 AM
JKo's Avatar
JKo
Very cool indeed. Don't know if you've seen it, but there's a K20 swap going on at the TrackMINI forum: http://www.trackmini.com/index.php/t...ap-into-a-r53/
Still waiting to see the first V6 swap tho... :D
EDIT: Nevermind, looks like you've already posted to the TrackMINI thread...
Old Jun 28, 2018 | 04:46 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
what are your power goals with it?
Old Jun 28, 2018 | 05:07 AM
J_L's Avatar
J_L
Awesome! Been loving my mini, but missing that 8k redline!
Old Jun 28, 2018 | 05:32 AM
DJLMINI's Avatar
DJLMINI
If you are going to cram this engine into the R53 it only makes sense to link it up to the CR-V drive train. More power and torque... with AWD!
Old Jun 28, 2018 | 05:54 AM
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
Cool. I was waiting for one of these, was expecting it into a R56 though
Old Jun 28, 2018 | 08:44 AM
downshift1's Avatar
downshift1
There is a company in the UK that is doing these. It makes sense as the K series engines make the same power N/A as we do supercharged, they are cheaper and have way more potential, and parts are plentiful.
Old Jun 28, 2018 | 05:03 PM
Kr4nG's Avatar
Kr4nG
Can you tell me what company is doing this? I saw z cars only doing this to the classic mini. They did the r53 one time and then they sold it and it got lost forever. I havnt seen it since. Mini tec in GA are doing the same with classics.
Old Jun 28, 2018 | 05:04 PM
Kr4nG's Avatar
Kr4nG
I already thought about it. But the front diff would hit the subframe which would need to be completly resigned.
As far as the power goes...IDK 500hp? well see
Old Jun 28, 2018 | 05:37 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Some very good stuff.
Old Jun 28, 2018 | 05:52 PM
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
So, what are you going to do after lunch Seriously that is a tremendous undertaking and it looks like you know what you're doing. You are to be congratulated. Can't wait to see the finished car.
Old Jun 29, 2018 | 11:31 AM
bee1000n's Avatar
bee1000n
Seeing that big engine sitting in front of the Mini's engine bay makes this project look like complete lunacy. I support it 100%!
Old Jun 29, 2018 | 04:27 PM
downshift1's Avatar
downshift1
Yeah it was zcar
Can you take a shot straight on from the front to see how low the oil pan is?
Old Jun 29, 2018 | 09:28 PM
Bnourai's Avatar
Bnourai
Wow
Old Jun 30, 2018 | 07:27 AM
Kr4nG's Avatar
Kr4nG
Yeah it was zcar
ill show you the picture but the pan is higher than the subframe. So the subframe is still the lowest part of the chassis. I will Never hit the oil pan even with my tein lowering springs.
Old Jul 5, 2018 | 04:29 PM
Kr4nG's Avatar
Kr4nG
This is the oil pan straight on. You can see the subframe is still lower.
Today I spent the day modifying the honda throttle cable and the throttle pedal. I wanted to use the s2000 pedal but I figured out a way to use the stock mini one. Not much modification to the cable itself. Just had to drill one hole into it. The pedal box had to be shaved inside a couple places.
Old Jul 5, 2018 | 07:44 PM
downshift1's Avatar
downshift1
Nice work, looking forward to seeing this thing rip!
Old Jul 6, 2018 | 08:09 PM
Kr4nG's Avatar
Kr4nG
Today I did the seam sealer and painted the rails. I used the self leveling seam sealer, which a bit hard to work with. I could have taped everything out but I would have wasted too much time.
Old Jul 7, 2018 | 04:11 AM
Whine not Walnuts
Makes my thread on adapting Chevy SS Cobalt Brembos look like child's play.
What is the weight of the Honda vs the MINI engine/trannie?
Old Jul 7, 2018 | 07:20 AM
Kr4nG's Avatar
Kr4nG
K-Series engine/trans: 403 pounds
I dont know the exact weight difference but I can tell you that the honda motor is way way way lighter.
Old Jul 7, 2018 | 08:03 AM
CRC's Avatar
CRC
Nice work. Takes some b@lls to cut into an R53 that looks that good. Looking forward to more updates.
Old Jul 10, 2018 | 09:43 AM
JABowders's Avatar
JABowders
Veteran: Army
looking great so far... waiting with interest for more.
Motor On!
Old Jul 10, 2018 | 07:00 PM
Kr4nG's Avatar
Kr4nG
not much progress today. I have started to put it back together. Couple of more things I need to do.
1. Passenger axle
2. All wiring including ecu
3. Exhaust manifold.
4. Clutch line
5. radiator and condenser
6. Shifter box and cables.
7. 3rd motor mount in the front
