Suspension R55 Clubman Lowering Springs
Old Jun 26, 2018 | 02:53 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Recommend me some lowering springs
I daily drive my Clubbie, and last year I averaged about 30k miles. Needless to say, my OEM struts are shot, and I want to get some springs in there too. I’d like something that rides close to stock, but give a slight performance boost. I’m planning some Bilstein SPs to go with the springs.
Old Jun 26, 2018 | 03:09 PM
thebombardier's Avatar
thebombardier
I liked my H&Rs when I had them. 1.5" drop.Be sure to look into whether linear or progressive spring rates are better for your shocks though.
Old Jun 26, 2018 | 03:35 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Bilstein offers a “cup” kit paired with Eibach Prokit springs, but I like the reputation of the H&Rs, too. Just curious if there is another option that is favorable here.
Old Jun 28, 2018 | 05:29 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We actually have some of the old NM R55 springs still in stock
https://www.waymotorworks.com/nm-eng...rings-r55.html
And they work great with the Koni Yellows
https://www.waymotorworks.com/koni-y...5-r56-r57.html
We found the Koni to ride better than the Bilstein.
https://www.waymotorworks.com/bilste...6-r55-r57.html
Old Jun 30, 2018 | 05:38 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I’ve had bad experience with Koni, and would prefer to not use them. Even with the lifetime warranty, they won’t cover R&R or return shipping. I have had better experience with the Bilstein, even though they ride a bit stiffer and lack damping adjustments.
Old Jun 30, 2018 | 05:53 AM
bratling's Avatar
bratling
Super Moderator
Do you have a stiffer rear sway bar yet? If not, this is a great time to put one in while you have the rear suspension disconnected.
Old Jun 30, 2018 | 06:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That is part of the plan
Old Jul 2, 2018 | 08:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
What is the difference between these three spring options:
https://www.waymotorworks.com/nm-rs-...s-r55-r56.html
https://www.waymotorworks.com/tsw-mi...6-r55-r57.html
Old Jul 2, 2018 | 08:55 AM
WayMotorWorks
Vendor
We actually ship you whichever NM springs you order. So if you order R55 springs we will send you the R55 version. Once we sell the last 2 sets there will only be one R55-R56 version from NM that will be the same. So as long as you select your model when checking out and get one of the last two R55 sets they will be the same. But once sold out NM will all be the same for R56 and R55 so the rear springs won't be different like they were in the old R55 set.
As for TSW springs we are currently out so they are not an option at this point.
Old Jul 2, 2018 | 09:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The difference between the R56 and R55 NM springs would be the amount of lowering in the rear? I prefer to have the rear ever-so-slightly higher than the front. Would that imply I want the R55 NM springs?
Do you have the Bilstein B8 sport shocks? I only see a listing for the B4 and B6 sets...
Old Jul 2, 2018 | 08:58 PM
WayMotorWorks
Vendor
The actual R55 springs are made to handle the extra rear weight of the Clubman, the R56 ones will tend to sag a bit more because they are meant for the hardtop.
I can get you the B8, but Bilstein says end of Aug/Sept before more are avail. but need to check tomorrow as I may have a set in the warehouse.
Old Jul 25, 2018 | 05:37 AM
KCLARK's Avatar
KCLARK
what Bilstein kits do you have "in stock" for R56 (anything)?
Old Jul 25, 2018 | 05:09 PM
WayMotorWorks
Vendor
We have B8 and B4 but not sure on the others. Email me with what you want and I can check tomorrow.
info@waymotorworks.com
grueinthebox
May 25, 2019 10:46 AM
chav
Dec 18, 2015 06:33 AM
chav
Dec 17, 2015 06:06 PM
ninjlao
Suspension
187
Sep 6, 2013 08:59 PM
Bahamabart
Suspension
Mar 16, 2005 11:01 AM
