F57 :: Convertible Talk (2016+) Cooper and Cooper S convertible (F57) discussions.
F57 Oil checking a '19 MCS 2.0L??
Old Jun 21, 2018 | 08:36 PM
Mad Mini 19's Avatar
Mad Mini 19
Question Oil checking a '19 MCS 2.0L??
I've got to know if any of you guys or gals rely entirely on the DIC to insure that your engine oil level is where it needs to be? I'm OLD, I'm OLD school, I'm not afraid to get my hands oily either, I still like the idea of pulling a stick and verifying engine/trans. oil/fluid levels. Has this become a redundant job or is the system that precise and reliable? Question I have is, can a person retro-fit a stick from an earlier model 2.0L motor into a later model? Just asking because I like to fix stuff that ain't broke (Ha, Ha). Thanx for any and all replies in advance. Mac
PS This might be a duplicate thread because I made one earlier and I think it went to cyber space.
Old Jun 21, 2018 | 08:45 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I recall reading a post that mentioned that the engine still had the casting where the dipstick would go. I'm old school but the electronic oil reading system is so simple that my wife will actually check it once in awhile. With the old dipstick I don't think she has checked the oil . . . ever.
I'm 100% in favor of using the new way. Everything else is pretty much electronic and computer controlled but people only moan about the dipstick. Drive by wire, electronic steering, electric rear differential. Applying the brakes automatically to keep you from plummeting off a cliff in a steep curve at fast speeds. Piped in engine sounds.
ranting over
Old Jun 22, 2018 | 03:35 AM
NBCGLX's Avatar
NBCGLX
I don't think a retrofit of a dipstick would be possible. The new MINI engines are part of the current BMW engine lineup, a lineup that has never included physical dipsticks. So my guess is, you wouldn't be able to find the proper parts and would end up having to drill into the engine block or something. Not worth it.
Old Jun 22, 2018 | 08:37 AM
Minnie.the.Moocher
B47 engine, not sure how compatible parts are but . . . http://www.realoem.com/bmw/enUS/show...diagId=11_5669
Old Jun 22, 2018 | 09:26 AM
NBCGLX's Avatar
NBCGLX
Interesting that the diesels have them!
Old Jun 22, 2018 | 09:30 AM
bratling's Avatar
bratling
Super Moderator
Well isn’t that interesting!
http://www.realoem.com/bmw/enUS/show...diagId=11_5500
If the diesel and gasoline engines use the same oil pan — and according to this, they do — then it may well be possible to retrofit a dipstick, unless the bung is sealed and welded closed.
Old Jun 22, 2018 | 02:57 PM
Mad Mini 19
ranting over
n
Yeah, I was going to buy a Ford Raptor a couple of years ago and yes they "pumped in" the motor sounds, REALLY! with a 428HP motor?? I hope I've "moved on" when AI cars are the THING! I have to admit, I do trust computers to do most "analyzing" today, I just didn't think People were getting that lazy. Thanks Mac
Old Jun 22, 2018 | 03:03 PM
Mad Mini 19
I might have to crawl under this thing and remove the splash guard and feel around the pan and block to see if a bung is there or not. Mac
Old Jun 22, 2018 | 03:15 PM
RockC's Avatar
RockC
Back in Jan. 2002 bought a new 2002 Porsche Boxster.
It had a dipstick to check engine oil and the electronic oil level checking system.
While I used the dipstick at oil change time to confirm I had added the right amount of oil -- like counting empty bottles wasn't reliable enough -- I never used the dipstick at other times.
The Boxster spoiled me being able to check the oil level prior to starting the engine from inside the car or after filling the fuel tank again from inside the car.
With my other cars it felt so odd to have to get out of the car and open the hood and use the dipstick to check the oil level.
Then I got a Porsche 996 Turbo. No dipstick option. In fact the digital oil level system would not let one check the oil level unless the engine was idling, up to temperature, and the car was level.
My 2018 Hellcat has a dipstick. What a pain to check the engine oil level. The telltale is hard to read and it hard to determine if what I'm seeing is oil that represents the oil level or what.
My JCW's digital oil level system works a treat and makes me wish my Hellcat had something similar.
One thing that one might not think about is the digital oil level system is not really for use when changing the oil, to measure the amount of oil one adds to the engine.
The engine oil is drained hot and drained for a certain amount of time. (Generally the factory service manual spells the oil drain prerequisites out.) Then a *known* quantity of oil is added to the engine. (My 2018 Mini JCW takes 5 quarts, and the oil comes in a 5 quart jug.) The engine is started and run and then the oil level is checked to make sure the reading *agrees* with the amount of oil known to be in the engine.
This is how the digital oil level system is confirmed to be working properly.
After my experience with my Porsche Boxster and Turbo and my albeit brief time with my JCW, no way I would ever consider trying to retro-fit a dipstick to the engine.
Old Jun 22, 2018 | 04:09 PM
Mad Mini 19
Dealer told me that the 2.0L holds 4.5 quarts with filter change. The fist 3 oil changes will be done by the dealer. Now he also told me that they would need to be done at 10K, again here I go...… 10K sounds a little high to me, especially with turbos, where higher temps are experienced and with the higher RPM's of a 4 cyl. I am a synthetic oil believer and I know oils are engineered better with their additive packages, but.....10K?? Mac
Old Jun 22, 2018 | 08:16 PM
Minnie.the.Moocher
10K or 1 year unless your driving and the computer algorithms warn on earlier miles. Most MINI "enthusiasts" on this board tend to pay for or do an in between oil change.
Old Jun 23, 2018 | 03:49 PM
Mad Mini 19
I'm kinda thinking the same thing at the moment plus, the car will only be used in the summer time. I have a chev Colorado for the winters here in Wisconsin. Mac
Mad Mini 19
Jun 21, 2018 08:00 PM
mimithemini
Dec 30, 2011 06:07 AM
the matey
Jan 11, 2011 02:33 PM
Sajuuk Khar
Jul 9, 2010 09:33 AM
johnp888
Mar 5, 2007 02:11 PM
