Navigation & Audio 06 Mini stock radio / stereo cannot turn on
Old Jun 16, 2018 | 10:05 PM
sushiman808's Avatar
sushiman808
09 Mini stock radio / stereo cannot turn on
2009 Mini stock stereo with boost CD player doesn't turn on / no display when pressing the power button, but the CD unit will accept and eject discs. Passenger side fuse box - fuse F23 checks ok, when I re-install the fuse, I can hear the CD unit energize. When I turn on my lights, the stereo and CD back lights illuminate
Old Jun 17, 2018 | 04:05 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Wondering if the push function of the switch is shot.
Old Jun 17, 2018 | 04:34 AM
sushiman808
If the push button is bad... any suggestions how to test/troubleshoot? A replacement radio/speed cluster listing on E-bay is easy $180
Old Jun 17, 2018 | 11:00 AM
rkw's Avatar
rkw
Why do you mention "radio/speed cluster"? Are you sure you have an '06? The radio is not integrated in '06 and replacements start at $30 on eBay.
Old Jun 17, 2018 | 12:45 PM
sushiman808
Apologizes.. 2009 not 2006. I just finish editing the post
Old Jun 20, 2018 | 02:20 AM
sushiman808
Update- I wanted to see/hear if when I insert a disc that I could hear the CD unit mechanically try to read it. Unfortunately once I insert the disc I couldn't hear any type of sound/movement inside. However I accidently inserted the disc upside down and strangely it spit it out. Is that a sign that the stereo unit is somehow working?
I haven tried to test the 2 rear fuses considering the CD unit is powered up and its a pain in the butt to remove the stereo unit
Old Jun 28, 2018 | 08:47 PM
sushiman808
The rear fuse checked ok..So I decided to buy a used CD unit on E-bay for about $80 (no speedometer) , there was a volume circuit board for $30, but didn't want to take the chance if it wasn't a power button issue. Not fun trying to disconnect/removing all them wire connector harness in the back area. (they make it look so easy on YouTube) But over all a person will normal skills using hand tools should take around 4 hours to remove and replace the stereo unit and panels. Once I connected the CD/stereo wire harness, I could hear the CD unit energize. Then when I turned on the ignition.. all the stereo/lower speedometer display and sounds awoke like magic! So the fix was due to a bad CD/stereo head unit.
One thing I didn't realize is and its a good troubleshooting point is with a normal working day to day Mini Cooper.. when you put your key in the ignition, there are normal status sounds such as when you open a door open or leave the hatch open. So If you don't hear any of those sounds.. you most likely have a bad stereo unit. If your able to slide a disc into the CD unit and your stereo don't still don't wanna turn on; you know all stereo fuses are good.
amelo73
Navigation/Audio
Aug 24, 2018 10:10 AM
derrickyoung
May 28, 2018 11:18 AM
wildcrazy442000
58
Oct 9, 2009 05:29 AM
Edge
725
Apr 4, 2008 04:15 PM
Jerseygirl
Mid-Atlantic
Dec 15, 2005 02:53 AM
