F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Brake light issue
Old Apr 24, 2018 | 08:03 PM
GDGR's Avatar
GDGR
Brake light issue
Anyone seen this one?
Yesterday, on my way home from work, I hit the brakes and got the warning on the dash that I had a brake light failure on the left side. Okay, I thought, I got this.
However, by the time I actually got home, the warning had dismissed itself and was not returning.
I checked it when I got home, and all was working fine, except that MAYBE the left bumper brake light (post-recall, so only the outer) was coming on a little slower than the others when the pedal is pressed. Maybe it was just in my head.
This morning's commute, no issues, no warnings. But when I got to the office, I locked the doors, then went around to the barn doors and opened them (comfort access). When you do this, the bumper-mounted brake lights come on. Only, no doubt, the left was MUCH dimmer than the right.
Tonight at home, I experimented a bunch, and although the light appears to be fine with the brake pedal, it is dim and a little bit flickery when it's on with the doors locked but the hatch open.
I tried swapping the two left-side bumper bulbs, since the inner one isn't used anymore -- but still, same issue. Appears to be wiring-related.
Car needs its 22K service in a month or so, so I'll probably let the dealer deal with it. But just curious ... anyone else seen something like that?
Old Apr 26, 2018 | 11:34 PM
ZiaMan24's Avatar
ZiaMan24
This was happening to my 2016 MCS Clubman. Warning came and went within a day. Then eventually came back about a week or so later, this time the light was actually out. Mine was the right side.
I was still under warranty, so I just went to the dealer to do my ~20K service and they just replaced it for me.
Less than a month later, the warning came back up, and it was the same brake light that went out. This time I asked the dealer to do a thorough inspection in case there was a wiring issue. They just replaced the bulb again and said it was probably just a bad bulb.
It's been another month or so now, and I am at ~23K miles. No issues.
ryanmike
May 31, 2011 10:16 AM
jmainella26
Dec 11, 2009 06:20 PM
EDM
Sep 6, 2008 06:18 AM
kristina
63
Dec 1, 2007 12:43 PM
