R60 Countryman Wheel Bearings
Old Apr 15, 2018 | 07:24 AM
iwashmycar's Avatar
iwashmycar
Just making this little thread since I replaced both front wheel bearings in our 2013 All4 this weekend. The writeups in the How-to section are pretty good, and it seems the R60 is very similar. I just never found anything specific to ours.
I did both fronts even though I knew only the driver side one was roaring. Likely due to the same pothole that took out a rim a month or two ago.
Steps were simple enough. Take off the two bolts that hold the caliper brackets on (and thus the caliper with it). I used a 5/8 since I didnt have a 16mm in my current tool box.
Next, the rotor.
Then take off the 32MM axle nut.
At this point the 4 bolts holding the wheel bearing are back behind right next to where the CV sits. They are also 16mm. Again I used a 5/8, a swivel, and a 3" extension to get to them. Was difficult to get a breaker bar on anything, just being on jack stands, but I managed. Tapped with a sledge to pop the assembly loose from the spindle. No problems with the speed sensor. It is just bolted inside the spindle. Bearing removal doesn't affect it.
The trick is to push the CV axle inward. This lets you get the big socket and extension back in there. On the first one I rigged up some ridiculous thing zip tied to the hub to keep the axle back.
On the latter one, I found jacking the suspension up slightly under the lower ball joint, helped to strighten out the CV shaft for better bolt clearance, and instead of the silly zip tie thing, just pushing the axle in and sticking a screwdriver in one of the axle notches held it back in there.
Still kind of a paint to get the bolts re-torqued but, doable. Also a piece of electrical tape on the swivel helps 'keep it up' while you are getting it back behind the spindle
Now all I have left is tire noise lol
Old Jul 18, 2018 | 11:53 AM
Crazy Airborne's Avatar
Crazy Airborne
Thanks for the write up, I have a grinding noise im thinking is bearing. I guess this is normal at 77k miles.
Old Aug 12, 2018 | 09:29 AM
gary dues's Avatar
gary dues
I'm having issues with the CV boot in the way of the top right bolt how did you get that one out
Old Aug 12, 2018 | 10:39 AM
iwashmycar's Avatar
iwashmycar
push the axle into the hub while trying to get to it. Otherwise slightly turning ‘wheel’ can help.
Old Jun 8, 2019 | 10:01 PM
tok282's Avatar
tok282
Torque specs
Thanks for this info iwashmycar ! Very informative with photo , would you happen to have the torque specs for the 4 bolt for the bearing and the nut for the axle ? Thanks !!
Old Jun 9, 2019 | 04:39 AM
iwashmycar's Avatar
iwashmycar
I don’t offhand. I believe I did the 4 bolts to one ugga-dugga, and the axle nut to three ugga-duggas ;P
Old Jun 9, 2019 | 10:04 PM
tok282's Avatar
tok282
Torque spec
Thanks for the reply iwashmycar . Would appreciate if anyone can please help me with torque spec for these 4 bolts for bearing and axle nut, as im planning to replace them this weekend , thanks in advance for anyone who can help !
Old Jun 10, 2019 | 05:36 AM
iwashmycar's Avatar
iwashmycar
I believe the hub bolts are 40 ft/lbs and the axle nut is 135 ft/lbs
Old Sep 28, 2020 | 11:30 AM
Rcraigs's Avatar
Rcraigs
More hints
Old Dec 20, 2020 | 02:08 AM
akmini's Avatar
akmini
Front wheel bearing - DIY Video You Tube
Here is a link to the best video I found for replacing the Front wheel bearing on a Mini Cooper Countryman. the audio is in French but that's not the important part anyways.I have replaced both front wheel bearings and one rear wheel bearing so far. Just waiting for the last one to go out the right rear.
Last edited by akmini; Dec 24, 2020 at 12:25 PM. Reason: added content about wheel bearing replaced so far
amd91fan
Feb 22, 2018 07:39 PM
JoeyBR60
Dec 7, 2017 07:53 AM
bdubya
May 6, 2016 05:31 AM
Kingerbeerman
Apr 27, 2014 04:55 PM
crazyworld
Dec 10, 2013 08:37 AM
