R60 filthy exhaust tips
Old Apr 6, 2018 | 09:40 AM
one73ronin's Avatar
one73ronin
filthy exhaust tips
i'm wondering if i should be concerned. my exhaust tips get really filthy over a short time (~2-3 weeks). i've said before that my engine sounds like a small diesel, and the exhaust tips look like im burning oil. should this be an indication that something is about to happen?
i did just have a road trip to portland and back, about 630 miles at 30mpg.
Old Apr 6, 2018 | 10:20 AM
MarioKart's Avatar
MarioKart
Vendor
very normal, the sound is also normal because it’s a direct port injected motor
mQubed Motorsport, Manic and RPM Power Tuning
Old Apr 6, 2018 | 10:35 AM
Yep, Mine does the same thing and you just need to ckeep cleaning it with the car or it will build up and then a pain to scrub off. Chrome polish helps.
Old Apr 6, 2018 | 02:08 PM
Fly'n Brick's Avatar
Fly'n Brick
Mine do too. I clean them with Bar Keeper's Friend. I even use it on the glass stove top for burned on stuff. It DOES NOT scratch.
Old Apr 6, 2018 | 04:18 PM
one73ronin's Avatar
one73ronin
thanks for the confidence boost, very appreciated
Old Apr 8, 2018 | 11:04 PM
jokerswild's Avatar
jokerswild
I found some Simple Green (if they're not too bad) or Meguiar's Hot Rims wheel cleaner (or equivalent) and a stiff wheel brush helps a lot to keep them looking clean. Note mine are painted black to start with, so it's not nearly as obvious when I get carbon buildup. For chrome ones, I'd use the same techniques as below, but periodically use some Mothers aluminum polish on them as well.
I start with liberally soaking the insides of the tips with Simple Green and then I scrub using a stiff wheel brush (one of these is what I use:
Amazon Amazon
) I follow it up with some soap & water. I take a microfiber towel and wrap it around the wheel brush, then dip it in the soapy water and scrub with that.
To get it really clean, I follow it up with a drill-mounted Mothers PowerCone (
Amazon Amazon
) dunked in the soapy water. That really keeps them shiny.
adrchn
Feb 26, 2015 06:48 AM
toomuchfun
Aug 6, 2007 04:03 PM
frank miller
Tires, Wheels, & Brakes
Dec 21, 2005 02:04 PM
gregsminis
Dec 31, 2004 03:07 PM
D.J.
Off-Topic :: Autos
Jan 28, 2004 09:16 AM
