Navigation & Audio Mini Cooper 2007 Has AUX port no AUX menu in Wave Radio
Old Mar 31, 2018 | 06:12 AM
donmarkon's Avatar
donmarkon
As i stated in topic description my Mini Cooper 2007 has Wave radio (single line screen) aux port is present but there is no aux selection in radio menus. Any tip how i can resolve this would be great as i really happened to finally use something better than FM radio transmitter ...
And more more thing would AUX menu on radio be always present or just when aux connection is detected
Old Mar 31, 2018 | 09:12 AM
H_C's Avatar
H_C
Press the m button (directly underneath the music symbol) until you see you see AUX.
Old Mar 31, 2018 | 11:01 AM
donmarkon's Avatar
donmarkon
Are you referring to this radio? when i need to press m button ?
Old Mar 31, 2018 | 02:03 PM
H_C's Avatar
H_C
Yes, the m button. It should cycle to FM/CD/AUX.
If that doesn't work, try the Mode button.
Old Mar 31, 2018 | 03:30 PM
rkw's Avatar
rkw
We do not have the Wave system here in the USA (the lowest system is Boost), and the buttons are arranged differently. You should have a button for selecting between radio and CD, and Aux should appear as one of the options (it might indeed be the case that Aux isn't displayed unless something is connected). You should probably use your Mode button (there is no Mode button on the Boost system).
Old Mar 31, 2018 | 05:12 PM
donmarkon's Avatar
donmarkon
Yes that is the problem mode button offers just CD and FM no AUX ... maybe my cable is faulty :-(
Old Jan 2, 2019 | 12:46 PM
Jorge Mujica's Avatar
Jorge Mujica
Hi, been able to solve this issue? i have a simialr problem with my US 2010 R56. Aux Input, no menu option. USB missing but with the menu option.
Old Jan 2, 2019 | 12:54 PM
donmarkon's Avatar
donmarkon
You need to enable it with bmw ncs expert
:D
Old Jan 2, 2019 | 12:55 PM
Jorge Mujica
:D
So the battery unplug did not work i guess.
Old Jan 2, 2019 | 01:00 PM
donmarkon's Avatar
donmarkon
:D
Nop
I needed to learn to use NCS expert (2 days of constant watching YT and reading)
Ordered cable, wasted 2 more days to find working NCS expert
Overal 5-6 days over 1 month wasted just to enable AUX which i dont use in the end
But it works now
Old Jan 4, 2019 | 08:54 AM
Jorge Mujica
Hey, thanks a lot for your feedback it was really uselfull. Already began doing some research online. Ive also find Icarly connector and App that seems to be doing the same job as NCS but supper easy, too good to be real. Are you aware of this tool?
About NCS, do you know if the complete lists can be download for free or i will surely have to pay for those.
Thanks again !!
Old Nov 20, 2020 | 11:12 PM
Asesapie's Avatar
Asesapie
So my 2008 R55 just had the same issue happen today. Was going to plug my iphone8 into the aux cord (which is a few weeks old and has worked great) and nothing worked no sound. Then cycled through the menu options and all of a sudden the aux and usb options are both gone for no reason. I also can’t select other options in the radio menu now, only tuner or radio.
so how does it work using this NCS expert program and what is needed to do so? Any ideas why this would just all of a sudden happen? Not charging at the same time. Just plugged into the aux input only.
spec35
39
Jun 19, 2017 05:54 PM
balopes
Oct 25, 2010 05:53 AM
MrMellowYellow
DC Metro MINIs (Archive)
43
Sep 5, 2008 07:49 PM
Darksky
Mar 31, 2003 10:01 PM
