R56 Very Confused with shaky steering wheel, Need help!
Hello all! I have a 2011 Mini cooper s LCI. My question/problem doesn't really matter the model, anyway I have a super shaky steering wheel problem. It had originally started 2 weeks ago when I put my summer tires and wheels on. Had them on last summer and no problems. Swapped them on and literally doesn't even feel they are connected. Above 45 mph it will move the steering wheel back and forth pretty crazy. So I had them balanced about 4 times and still didn't work. I might have found a bend in one of the summer wheels.. Okay. No problem! I swap my stock setup from the factory and I thought it was going to work and now it just does the same thing! Was perfect 2 weeks ago, no problems then.. What do you think it could be?? I have balanced both sets I have put on there numerous times, I had an alignment not even 6 months ago and there are no bends in my stock setup. Please help!
Similar happened to me. Turned out to be a bad tire. OK one day, the next wobble. Took it back to tire shop where I got them, they swapped the tires front to back, problem went away. Ended up replacing problem tire..
As mentioned it could be anything within the suspension once you have ruled out wheels/tires. On mine it was the axles that needed replaced.. It shook from around 40-60 mph but was much better above and below that some how... Hapened right at 100,000 miles but I probably helped it with lowering my car more then average..
My car has about 83k miles on it. Went to the shop last week and they said my suspension looks fine. It's driving me crazy not knowing what it could be! maybe a wheel bearing? I am not for sure.
Usually wheel bearings make noise not shimmy. Are you running any spacers on the wheels? If so you may need to remove to see if the shimmy goes away and eliminate them as the problem. By the way when you took into the shop to check the suspension what was their diagnosis for the shimmy when they road tested the vehicle?
I am not running any wheel spacers on my mini and never have before. They diagnosed it as a bent rim in the front left and told me to swap my other wheels on to see if it continues and I did and it just continues. Now that I call to make an appointment, they aren't able to get me in til next thursday!
Navigation & Audio install navigation cic to pre LCI R56???:confused::confused::confused:
Dimitris Sofianopoulos
Sep 22, 2015 03:07 PM
astroBlackMetallic_Mini
Tires, Wheels, & Brakes
17
Sep 4, 2014 10:24 AM
mariocaz
Nov 13, 2012 09:01 PM
bigallen
24
Nov 30, 2007 03:46 PM
mini b
11
Jan 13, 2007 05:08 AM
