R55 Custom pillar pod project
Old Mar 24, 2018 | 09:23 AM
Joshua Brightbill's Avatar
Joshua Brightbill
I covered the original pillar in aluminum foil to protect it, then fitted some 2 inch PVC pipe in place and added some foam for extra space.
Next I started the fiberglass and resin layers. I did between 2 and 3 as needed.
Its ugly now, but it will take its shape.
Letting it cure before more detailed triming.
Old Mar 24, 2018 | 09:33 AM
Joshua Brightbill
Layers of fiberglass body filler bondo. The original pillar is out by this point. Lots of sanding ahead.
Tools make life easier.
Just working to get it nice and even. I repete the bondo filling as needed, then i move to red putty to fill the smaller imperfections. After that i prime it.
Done with that jazz, and ready for plasti dip. I cleared the foam out of the pillar with a knife and a dremmel.
Old Mar 24, 2018 | 09:38 AM
Joshua Brightbill
I made litte inserts to keep the dip out of the pods so i wouldnt have to sand the inside again. Saving time and making sure the gauges fit properly.
Old Mar 25, 2018 | 08:40 AM
cornjuice's Avatar
cornjuice
that doesnt look half bad at all! What cluster setup you installing? AFR/Boost/coolant temp?
Blaxin41
Mar 12, 2018 01:08 AM
Red Bull
Dec 3, 2012 12:23 AM
hardbeat
Apr 4, 2009 07:44 AM
naffets
Jul 20, 2007 05:43 PM
Profpatpending
Feb 20, 2006 07:36 AM
