FS:: NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813
Old Mar 23, 2018 | 03:16 PM
renn90's Avatar
renn90
Category: Exterior
Price: $25
Item Condition: Brand New
SOLD OTHER PARTS STILL AVAILABLE BELOW
Brand NEW Pair of MINI OEM Magnetic Stone Guards
BMW Mini Part # 82110304813
protects area in front of rear wheels.
Made to fit R50-R59 models
With slight trimming can fit Countryman /Paceman and F54+ models.
Will ship to any U.S. state for $6
ships in factory packaging (cardboard envelope as pictured)
Brand New in never opened package (stored properly in smoke-free, odor-free, pet-free, conditioned building.
I Bought this for my R53, never opened the package, and then sold the car.
Product Details per manufacturer:
These factory black magnetic stone guards made out of a material to protect the rear rocker to wheel arches. Cut with a contour to fit that particular corner which curves out on your MINI and sometimes takes a beating from road debris. These large magnetic guard are easy to install and butt against the lower rear wheel arch on the paint.
Make sure the magnetic side is clean and your paint is clean before applying to not scratch the paint.
Also have many other brand new and good used Mini parts listed and not listed:
Renn 90 Parts Sale for R53, R50, some for R52
I’m asking that buyers spend at least $15.
Shipping is $0-$25 to most states (depending on what you want) - (does not apply to wheels and tires)
Can check parts fitment, and use (mostly with pics) at ecstuning.com
MAINTENANCE ITEMS:
Haynes Service Manual (Red Hard Cover, R50, R53, 2002-2006, Very Good) doesn’t cover features of convertible or JCW, or cvt $15 SOLD;
Engine Oil Drain Plug - new in package 11137513050 $7 SOLD;
BMW Sunroof Lubricant (1 .7 oz Pack) 83192157321 – new: $4;
Mann CU 4624 Cabin filter – new: $6 SOLD;
Power steering reservoir tank - Vaico new in box 32416851217: $14;
Gatorback Belt 4060537 6PK1365 – new in sleeve $11 SOLD;
Gates Belt Micro-V ko60535 (never used, but in old stained sleeve) $8 SOLD;
OEM Supercharger Pulley – used but like new $15;
Quick-Valve brass alloy oil change valve (replaces drain plug) with straight and 90 degree plastic extensions – new in package F106S $20 SOLD;
Mount for Power Steering Pump – new in package 07136778958 $8 SOLD;
R50 R52 R53 Valve Cover Gasket KIT with Seals for Plug Wires new in package elring Part # 11121485838 $15 SOLD;
R50 R53 Genuine Mini BMW Rear Wiper Blade new in package 61627129280 $9;
Pentosin CHF 11S MINI-Spec Power Steering Oil – new unopened 1 Liter Cans CHF11S (2 Quant.) $30 SOLD
TOOLS[/B] THIS CATEGORY is ALL SOLD
Belt Tensioner Release Wrench (aftermarket Chinese) – new $25 SOLD;
Schwaben 36mm 6-Point Oil Filter Socket - 3/8" Drive OC-03 – used VG $8 SOLD;
SUSPENSION
OEM Front End Links MINI from R53 – used VG (2 quant.) $16 or $8 each
OEM Stabilizer Support Genuine – Rear MINI used – VG 33556778828 $10
OEM Sway Bar Bushing – Rear MINI used – VG 33556756151 $4
MODS:
Schroth Rallye 4 Quick Fit QuickFit Harness Part Mount Tail Strap Connector from Schroth Replacement Part #01400 Kit – new $36 each (1 avail - 1 SOLD);
K&N Filter Recharge Kit – new in unopened box 99-5050 $10
WHEELS AND TIRES:
Mini OEM Logo Center Caps – used VG 36131171069 (4 quant.) $36 or $10 ea.;
Mini OEM Wheel Center Cap Logo Sticker new in package 36136758687 $4;
R85 OEM 17” S-Lites WHEELS SET – used VG-Excellent (listed on NAM) 36116773945 $450 SOLD;
R81 OEM 15” WHEELS SET - used VG perfect for snow tires VG (listed on NAM) 36111512458 $375 set or $120 each;
SET OF 4 Michelin X - Ice Snow Tires 9/32 Excellent 175/65 R15 $249 OBO make offer
PROTECTION / STYLING:
"S" Logo Trunk Mat / Cargo Liner Black Genuine MINI – used in box VG (listed on NAM) 82120306969 R50 & R53 $38 SOLD;
Magnetic Stone Guards (Genuine MINI - New in unopened package protects area in front of rear wheels) (listed on NAM) 82110304813 $25 SOLD;
White Bonnet Stripes, Custom - close match to OEM $20;
Portfolio (2006 OEM Black Leather/Leatherette) for Owner’s Booklets (including all booklets except owner’s manual – 5 booklets Very Good –Excellent and Portfolio Excellent $15 SOLD;
BRAKES:
Brake Pad Sensor Rear Only URO 34356761448 – new in package $4 SOLD;
Front Retainer Clip (brakes) Ate Brand 34111512715 - new $5;
Hawk HP Plus Brake Pads (Rear Set – 4 pads) used 5/16”+ remaining HB445N.610 $35;
Hawk HP Plus Brake Pads (Front Set – 4 pads) used ¼”+ remaining HB444N.685 $55;
ATE Standard Brake Pads (Rear Set – 4 pads) used ¼”+ remaining $8 SOLD;
TRIM:
R53 Interior B pillar covers (NOT black – Light Gray) used VG (Right & Left - 2 quant.) $35 or $18 each
SPECIAL FASTENERS
Torx Bolt M8x16 OEM Mini BMW (for rear hatch hinge, & other) 07131166764 (2 quant.) $5 or $2.50 each
VARIOUS OEM SEALS and FASTENERS THIS CATEGORY is ALL SOLD:
– ALL Genuine Mini unless noted otherwise. All New in packages (prices are for entire quantities)
The hardware listed below is often broken while performing basic disassembly.
Plastic Rivet 07130702966 (10 quantity) $5 SOLD;
Plastic Rivet Expanding 51118174185 Vaico Brand (10 quantity) $8 SOLD;
Screw 07131022174 (2) $1 SOLD;
M8-8 Lock Nut 07119905374 $1 SOLD;
Rear Arch Panel Clips 07137036159 (2 quant.) $2 SOLD;
Front Wheel arch Plastic nut 07130702715 (2 quant.) $3 SOLD;
Exterior Trim Clips 07132757821 (2 quant.) $1 SOLD;
42-Pole Electrical Cover Cap 61136905185 $5 SOLD;
Torx Screw 32416754507 $2 SOLD;
Hex Bolt M6x25 (for bumper valence & other) 07147117693 $1 SOLD;
Expanding Nut – Plastic 07130656754 (5 quant.) $1 SOLD;
Expanding Nut – Plastic 07130672440 (9 quant.) $7 SOLD;
Metal Green Interior Parts Clip 07130766476 (5 quant.) $15 SOLD;
Fillister Head Self-Tapping Screw 07146977198 (4 quant.) $10 SOLD;
Fillister Head Self-Tapping Screw 07147146367 $1 SOLD;
Oil Dipstick O-ring 11437513891 (2 quant.) $2 SOLD;
Crank Shaft Sensor O-ring VictorRenz Brand 12147514983 $1 SOLD;
Cam Shaft Sensor, Pulse Generator O-ring VictorRenz Brand 12147514984 $1 SOLD;
Air Intake Hose Clamp 13721491752 $3 SOLD;
Air Intake Hose Connector Small Tube 13727513325 $5 SOLD;
Headliner White Plastic Clips 51447111066 (2 quant.) $5 SOLD;
Insulator Ring Gromet for Ignition Coil Bolt 12137510737 $2 SOLD;
Blind Plug (for body holes) 07147140850 (2 quant.) $1 SOLD;
Attached Thumbnails NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-1aa-copy.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-img_7702.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-1-copy.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-2-copy.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-3-copy.jpg
NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-img_7698.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-img_7699.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-img_7741.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-img_7770.jpg   NEW Pair MINI OEM Black Magnetic Stone Guards MINI BMW# 82110304813-img_7771.jpg
Old Mar 28, 2018 | 11:49 PM
renn90's Avatar
renn90
List Updated
Thanks to all buyers
Old Mar 30, 2018 | 06:13 PM
renn90's Avatar
renn90
List Updated
Old Mar 31, 2018 | 12:46 PM
renn90's Avatar
renn90
List Updated
Thanks Steve and Cooper and everyone who has shown interest.
Old Apr 2, 2018 | 08:53 PM
renn90's Avatar
renn90
List Updated
Thanks Paul and everyone who has shown interest.
Old Apr 3, 2018 | 09:21 PM
renchjeep's Avatar
renchjeep
Still have the magnetic stone guards?
Old Apr 4, 2018 | 03:06 AM
renn90's Avatar
renn90
Stone Guards are Still Available.
PM if interested in purchasing.
Old Apr 8, 2018 | 08:32 AM
renn90's Avatar
renn90
Thanks Pat,
and thanks to all who have shown interest and bought misc. items.
Old Apr 18, 2018 | 04:29 AM
Shiner's Avatar
Shiner
If the k&n recharge kit and the sunroof lube is still available I’ll help out and purchase. I’ll be at my current address for another 12 days, does that give you enough time? Thanks, Todd
Old Apr 18, 2018 | 05:07 AM
renn90's Avatar
renn90
Still available and will arrive to any state in 2-3 days after payment. Please PM me your address for a shipping quote.
Trashed
Dec 26, 2017 02:55 PM
blackie
Aug 24, 2017 03:12 AM
