Suspension Installing Rear Adjustable Control Arms
Old Mar 21, 2018 | 05:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
In the next month or so, whenever the weather decides to break, I'l be installing some coil overs and rear control arms.
My question, though, is how difficult is it really to install the rear control arms? I know its only two bolts on each side, but how difficult is it to remove the inner bolt from the sub-frame? I know the bolt is close to the gas tank, but is there enough room to get it out without having to drop the sub frame? Am I getting myself paranoid over this?
Old Mar 22, 2018 | 02:09 PM
Zsm's Avatar
Zsm
Nik,
Not sure if you've posted in the R55/R56 area and received input?
Pelican Parts has a DIY: MINI Cooper R56 Control Arm Replacement
Old Mar 22, 2018 | 02:34 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Originally Posted by Zsm
Nik,
Thanks. Ive read through the DIY guides, but I’m getting myself worked up concerning removing the bolt on the inside end. Just want to be reaffirmed that it will come out without much of a clearance issue. It will be my first suspension project on the Mini. Everything seems very tightly placed.
Old Mar 22, 2018 | 03:36 PM
Whine not Walnuts's Avatar
Whine not Walnuts
I changed mine a couple of weeks ago and it was not that bad.
I rate MINI jobs by how many times I say PintheA or MFSofB and actual don't think I said either.
Old Mar 22, 2018 | 03:45 PM
Zsm's Avatar
Zsm
Looks like the R55 has the same design as the R53.
Did you see this DIY? Rear Camber Links
Bill talks about pushing the aluminum heat shield to gain some space to remove the bolt. I didn't need to, but it is tight in there. Not sure if the R55 is different here. Either way, again, not a problem. Same as what I did.
Old Mar 22, 2018 | 04:49 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Sounds like I’m just getting myself worked up
Thanks for the confidence boost!
Old Mar 27, 2018 | 12:49 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Just got done installing the HSport rear lower links, and it wasn’t a terrible job. Had to find a 3/8” 18mm socket and a stubby extension to fit between the subframe and the gas tank. Other than that, out with the old and in with the new! Now just need to get the coilovers installed, and head to the alignment shop...
Old Mar 27, 2018 | 02:28 PM
Zsm's Avatar
Zsm
Sounds like success!
Did you torque down the mounting bolts with the control arm with the hub approximately where it would be if the car was on the ground? Helps to keep the bushings from twisting/tearing apart over time or so I was told.
Old Mar 27, 2018 | 03:21 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I did not torque on the ground or loaded. I smeared a ton of grease on the sides of the bushings to get the arms wedged into the brackets that, even with the bolts torqued, there was still enough movement of the arm to allow the suspension to settle.
alex123
Suspension
16
May 18, 2011 07:29 AM
jbsf3
Suspension
Jun 16, 2005 04:08 PM
OutMotoring
Jul 2, 2004 10:00 AM
MTVFlorida
Mar 26, 2003 11:27 PM
