R56 What is this one?
Old Mar 12, 2018 | 09:43 PM
Pramuk's Avatar
Pramuk
What is this one?
What is s this one for?
On my 2008 MCS. Front left(driver side)
Old Mar 12, 2018 | 10:42 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
That's the sensor for leveling the Xenon headlights. There's a similar one on the rear suspension.
Old Mar 12, 2018 | 10:44 PM
Pramuk's Avatar
Pramuk
Oh. How it works? I have no idea
Old Mar 12, 2018 | 11:23 PM
squawSkiBum
Moderator
Have you ever noticed when you turn on your headlights that the beam goes up and down a little? That's the leveling adjustment. The sensor measures the angle between the lower control arm and the fixed part of the chassis. The signal goes to the car computer which then adjusts the headlights. If you put a few hundred pounds of stuff in the back, the rear of the car will sag down and the front bumper will tilt up. That would point the headlights up - but the leveling sensor adjusts for it.
Old Mar 13, 2018 | 05:45 AM
"That's the sensor for leveling the Xenon headlights. There's a similar one on the rear suspension."
+1
I hit the little pivot joints once a year with a little grease so they dont rust and hang up and snap the little plastic arm.
Old Mar 13, 2018 | 07:46 AM
isamin's Avatar
isamin
To avoid future maintenance problems, affix a "NO FAT CHIX" sticker to the passenger side door.
ISAMIN
Old Mar 14, 2018 | 06:18 AM
S-2013's Avatar
S-2013
That's probably not a bad idea. I'm gonna spray some white lithium grease on the pivots next time I'm under there. Thanks.
Old Mar 14, 2018 | 07:40 AM
Ok, yep.
Davbret
55
Mar 10, 2019 03:04 AM
chows4us
Off-Topic :: Autos
31
Jan 29, 2007 11:54 AM
WorldOnePerformance
Nov 3, 2005 07:26 PM
PDX_Mini
May 1, 2003 09:46 AM
SuperMINI03
Mar 17, 2003 08:08 AM
