R57 LOUD static noise
Old Mar 12, 2018 | 08:18 PM
Gwapes's Avatar
Gwapes
LOUD static noise
Hi All: My 2010 Cooper S convertible has developed a strange problem. It has stumped the mechanics and car electricians I have consulted. I believe the problem is connected to the "car access system," but that is just my guess. In short, when I use the key fob to unlock the car, the doors unlock and after a brief moment, very LOUD static noise starts to blare out of all the car's speakers. It is not a problem with the radio which works fine (though I can barely hear it over the static noise) and I cannot raise or lower the static noise volume using the radio volume control. While driving, the static noise is nonstop. If I unlock the doors, but do not open any of the doors, the static blares for a couple of minutes then stops. The, if I open any door, the trunk or the hood, it triggers the static noise. When I lock the car with the key fob, the loud static noise will continue for 1-2 minutes and then it stops. Otherwise the car access system works perfectly. Any thoughts would be greatly appreciated.
Old Mar 21, 2018 | 02:32 PM
MiniToBe's Avatar
MiniToBe
can you post a short video for us.
did you scan it for codes using a bmw/mini sw?
what triggered this even from the beginning?
Old Jun 1, 2021 | 10:39 PM
minicoopcali's Avatar
minicoopcali
2010 clubman
I have no clue what the cause is, but this has happened to me in my clubman. It happened just recently. It was so loud I had to park my car and panic a little. After about 10 min it ended and hopefully won’t happen again.
redZip
R57 :: Cabrio Talk (2009+)
Oct 15, 2009 01:51 PM
mordecai
Aug 5, 2009 06:36 PM
uRabbit
May 2, 2008 11:56 PM
MrX
23
Dec 16, 2006 05:31 AM
Pat_Cooper
Dec 14, 2004 09:54 PM
