Suspension S Suspension in a Justa
Old Feb 23, 2018 | 11:30 AM
devalkk's Avatar
devalkk
I have a 2013 Justa. What differences are there in the suspension between the S and the Justa?
Would it be possible to swap an S suspension set up into a Justa, and what would it take?
Also, looking at parts, I saw shocks for Standard suspension and Sport suspension. What are the differences between those, and how could I find out which I have? I assumed all Minis got the Sport Mode button.
Old Feb 23, 2018 | 11:35 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Check realoem.com for part numbers to compare.
Old Feb 23, 2018 | 01:36 PM
Ive's Mini's Avatar
Ive's Mini
My 08 non-s has the sport package and is the same components as an S. Not every S has that sport package, so my car has a visually different stance than an average S has. Springs, Struts, Sway bars. Those areas are where you will equal or surpass a S.
Old Feb 26, 2018 | 09:59 AM
mbwicz's Avatar
mbwicz
All of the parts will physically bolt in either a base model or an S. From the factory the S has a different set of shocks and springs.
Most aftermarket parts will generally be superior to the S components (koni or Bilstein struts, for example). If you don't want to lower your car, stock springs are about the only options (aftermarket springs are stiffer, but generally drop the ride height).
So you could replace your justa suspension with S components. Or you can go aftermarket. There are plenty of threads here describing the benefits or issues with stock vs. aftermarket.
My opinion - swap out the rear sway bar, that will make a big difference on how your car responds. Not difficult to do, about $250 or so plus install. Then see what else you want to change.
Have fun,
Mike
Old Mar 2, 2018 | 04:54 AM
devalkk's Avatar
devalkk
Thanks mbwicz, that is exactly the feedback I was looking for. I appreciate the insight.
1ncmini
Oct 6, 2011 03:42 AM
edgar_fletcher
Dec 13, 2010 06:10 PM
DOC4444
Suspension
50
Nov 3, 2010 08:56 AM
Carve906
Oct 31, 2009 05:34 AM
