R50/53 Installing battery tender
Old Feb 8, 2018 | 11:47 AM
Nitro1's Avatar
Nitro1
Hello. I searched the forum and could not find a play-by-play on how to install a battery tender to our 2005 Cooper S. Anyone have an easy step by step instructions or a video link? Thanks so much.
Old Feb 8, 2018 | 11:49 AM
Jimmyjamesphan's Avatar
Jimmyjamesphan
The red line goes to the + symbol and the black line goes to the - symbol.
Old Feb 8, 2018 | 11:54 AM
JABowders's Avatar
JABowders
Veteran: Army
You could just watch a video on a generic installation of a Battery Tender, then just adapt it to the specific needs of the MINI. the big question is do you want to hard-wire it, or use the clamps? If you want to hard-wire it where do you want to store the connector? One possibility is you could hard-wire it to the Jump Studs under the hood and run the wire to the front grill so you can pull the connector through the grill opening, so you can connect the Tender without opening the Bonnet.
Motor On!
Old Feb 8, 2018 | 12:01 PM
Nitro1's Avatar
Nitro1
Yes, looking to hard wire and run it through the front grill. The jump studs look like the best option, but I dont think the tenders cable will reach. I need to check later tonight.
Old Feb 8, 2018 | 12:06 PM
JABowders's Avatar
JABowders
Veteran: Army
You can ground the Negative to the Engine Mount close to the Positive Lug.
Mounting to this area is easier than connecting to the battery in the trunk under the floor panel.
Motor On!
Old Feb 8, 2018 | 12:08 PM
AnOldBiker's Avatar
AnOldBiker
4th Gear - An Official NAM Greeter
There are slight changes between years and models. When you want help, it is best to inform of what you own or put it in your signature so it comes up everytime. Makes it eaiser for those who want to help.
Old Feb 8, 2018 | 12:15 PM
JABowders's Avatar
JABowders
Veteran: Army
I just made this to add...
Old Feb 8, 2018 | 12:17 PM
JABowders's Avatar
JABowders
Veteran: Army
Well since he posted in the Gen 1 section and he mentioned his car was a 2005 S, I'm pretty sure he was asking a fair question for a R53.
Old Feb 8, 2018 | 12:21 PM
Nitro1's Avatar
Nitro1
I did state it was a 2005 Cooper S. I should have put it in the title of the thread.
Old Feb 8, 2018 | 12:24 PM
Nitro1's Avatar
Nitro1
Thanks, this is what I was thinking as well.
Old Feb 8, 2018 | 12:57 PM
JAB 67's Avatar
JAB 67
I put my Battery Tender in the rear. Easily connected. But be sure that if your battery is dead or dying you not close the hatch because if you do you will have to dig under the rear seat for the emergency latch release.
Old Feb 8, 2018 | 01:23 PM
Nitro1's Avatar
Nitro1
Thanks. Are you able to close the hatch with the tender cable sticking out?
Old Feb 8, 2018 | 03:39 PM
JAB 67's Avatar
JAB 67
No.
Old Feb 10, 2018 | 02:58 PM
A383Wing's Avatar
A383Wing
I have a tender on my 2004 R53.....sits right on top of the fuse box under the hood....red lead hard wired to the "+" terminal under the hood next to air cleaner box....."-" lead from tender to ground.
I open hood and run the extension cord from the house just next to the hood release up to the tender 110v electrical plug, then close hood
Old Feb 11, 2018 | 07:37 PM
freddmc's Avatar
freddmc
Isd there a particular reason for a battery tender on a Mini?.I don't have that on any of my other vehicles.
Fred
Old Feb 20, 2018 | 01:44 AM
MINIKB's Avatar
MINIKB
Fred
If your MINI is not a daily driver, this is a must. We average about 500 miles per year on the MINI and the original battery lasted 13 years It is always plugged in when in storage.
Old Feb 20, 2018 | 05:03 AM
Derek86's Avatar
Derek86
Fred
Just keeps the battery charged correctly during storage. I run a tender on every vehicle I store over the winter. Cheaper than new batteries every year.
Old Feb 20, 2018 | 02:43 PM
gsfent's Avatar
gsfent
If not long enough you can get extension cables. I think the shortest is 6' however. Easily found on fleabay.
Regards.
Jerry
roadrunner255
Dec 5, 2017 11:38 AM
kg4fxg
Electrical
Jan 1, 2014 03:07 PM
bluesman77
Mar 10, 2011 10:47 AM
80Spitfire
Feb 3, 2009 05:12 PM
aa3jy
Nov 25, 2003 05:12 PM
