Hi all, this is my way of giving back to the community. I received a R56 shift **** and boot a while back as a gift and didn't get around to installing it until now, when I discovered that the boot is too narrow and that the shift **** is too deep to slide on.
I used this as an opportunity to try something with the overly tall shifter and my ripped boot from the R53.
Supplies required:
R53 shift boot and bezel
R56 shift ****, boot and bezel
5/8" outer diameter x 1/2" inner diameter vinyl tubing ($6.67 for 10' at home Depot)
Measuring tape
Hacksaw
Towel paper
Utility knife
Step 1: Remove shift boot bezel by grabbing it firmly and prying upwards.
Step 2: Pull the boot up to reveal a zip tie holding the boot on to the shift rod. Cut the zip tie.
Step 3: Grab the shift **** with both hands and pull upwards towards the roof to remove. Tired R53 shift ****
At this point you should have the boot with bezel and **** off of the shifter assembly.
Step 4: Mark 2.5" down from top of shift rod and place paper towel or old rags around the shifter area. Then proceed to cut horizontally with a hack saw. Shifter after cutting and removing plastic collar using channellock pliers
Step 5: slide 3" of 5/8 OD x 1/2 ID vinyl tubing into the R56 shift ****. Don't worry if you can't get it all in.
Step 6: Fold your r53 shift boot into the bezel, leave about 2" of material and cut off the rest. Modified r53 boot
Step 7: Reinstall then r53 shift boot bezel with modified boot from above.
Step 8: Slide R56 shift boot and **** assembly (with the vinyl tube inside) over the modified shift rod and force the **** down as far as possible as it compresses the tubing and fixes itself in place.
Step 9: Push the R56 boot and bezel firmly into place. Finished install
Step 10: Enjoy your new short shifter and shift ****!
Took me about 1.5 hours including painting my R53 bezel and going to the store for tubing.
