R58 Brake question
Old Dec 23, 2017 | 07:44 PM
jtp01's Avatar
jtp01
Brake question
I was upgrading the brake lines and doing some other work and the reservoir ran dry. So I’ve bled the brakes manually but don’t seem to have the stiff pedal I had before. If I understand correctly, I need to activate ABS to thoroughly bleed. I only have the Carly app and there is no option I can find to do this. Will the following tool allow me to activate ABS while bleeding my R58?
https://www.ecstuning.com/b-schwaben...hoCdW0QAvD_BwE
Old Dec 23, 2017 | 08:40 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You should be able to manually bleed it without activating the ABS. We never have to in the shop. But sometimes it does take some pumping to get it done.
Old Dec 26, 2017 | 06:51 AM
Hello, yes the schwaben tool will pulsate the ABS to bleed the system. Among many other uses.
Most of the time you don't have to do this unless you have replaced the ABS itself or opened a line up on or near it. I have done many brake bleeds on the MINIs and using the brake bleeder tool ( schwaben or Motive) and new fluid and you are gtg.
Old Dec 29, 2017 | 05:23 PM
jtp01's Avatar
jtp01
ECS - I purchased the tool and found the test to activate the pump but I receive a message that the ECU rejected the test. Any ideas on how to solve that problem?
Old Jan 2, 2018 | 07:33 AM
Not on that one, I have seen it work. Did you update the tool online first?
pancakex
Jul 31, 2006 02:59 PM
Arly
Tires, Wheels, & Brakes
Jun 8, 2006 06:39 AM
MiniPilo
Oct 14, 2004 06:03 PM
rory
May 23, 2003 08:07 AM
