Tires, Wheels & Brakes
TCE/Wilwood for your MINI
Old Dec 5, 2017 | 10:52 AM
toddtce's Avatar
toddtce
Don't pass through as much as I used to...seems I'm too busy in the shop today!
Just a reminder: TCE has all your MINI needs covered today as much as we did nearly 15yrs ago. And more!
From R50 12.2" Wilwood factory kits to the latest generation 5 Lug cars.
TCE is also your sole source for all you Contryman and Paceman owners! Our exclusive arrangement with Wilwood assures you of the same quality and serive you'd expect when dealing with Wilwood directly. *Remember: TCE was the pioneer in many of the kits that are now Wilwood factory kits....the rear parking brake kit...13" DP6...all TCE designed product. Meaning you get the TCE history into everything we sell and build!
15" wheels...16...17...and 18" wheels...our 11.75, 12.2, 13 and 14" kits will fill the bill and the wheel!
Check out the TCE WEB PAGE for all things relating to your needs. And as always; questions are a phone call away.
Old Dec 12, 2017 | 06:26 AM
toddtce's Avatar
toddtce
Not to late to buy something for yourself...err...your MINI! Pick up a four wheel BBK for your car and you can have it for Christmas if you get an order in the next few days yet!
WOW! All for corner for under $1700!
Old Dec 12, 2017 | 06:59 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
the first time you change pads at the track with these wilwoods you will realize they are worth every penny
Old Dec 12, 2017 | 06:33 PM
Eddie07S's Avatar
Eddie07S
No, it is after a session on the track and your brakes aren't mush that you will realize they are worth every penny. Plus there is the "change the pads at the track" thing that takes less time than it does to jack the car up and pull the wheel off.
Todd has been great to deal with.
Old Nov 7, 2018 | 11:35 AM
toddtce's Avatar
toddtce
Figured near a year on I'd give this old post a 'bump'.
Have not been as active in the MINI market as I was years ago. Less of the mod based buyers on your end and more custom work on my end it appears. But...still here and still putting out the same quality products for your ride. Met a nice guy from the UK today who stopped by for some advise and pad wear plates. Sure we'll do some more business in the future.
Product line today includes all the popular MINI models including the Clubman and Paceman for you larger model owners.
Need service parts: pads, rotors, caliper parts? TCE has you covered there as well. I've got hundreds of pads in stock as well as seal kits, pistons, tension clips and even the pad retainer clips. SERVICE PARTS BRAKE PADS
Shopping for your first Brake Kit? No problem. Call or email me and we can discuss the options and help find the best solution for your needs!
Old Nov 7, 2018 | 12:46 PM
Eddie07S's Avatar
Eddie07S
What he said!
Old Aug 21, 2019 | 04:06 PM
toddtce's Avatar
toddtce
BUMP! Still here, still pumping out the Big Brake Kits!
Old Aug 22, 2019 | 05:58 AM
Eddie07S's Avatar
Eddie07S
I finally got a chance to “test” out Todd’s custom 1” thick rotor version of the 12.2” Wilwood BBK. This was at Watkins Glen, which is extremely hard on brakes. Todd’s bigger BBK worked flawless. A big improvement over the base Wilwood version with the 0.81” thick rotor. So nice to have brakes that you can count on to be consistent on a track like WGI. As everyone knows, it is all but impossible to install any sort of true brake ducting on the R56. For me, this upgraded BBK has taken away the need to think any further about brake ducts...
TCE - Definitely the place to go to for brakes!
Old Aug 22, 2019 | 08:30 AM
toddtce's Avatar
toddtce
Originally Posted by Eddie07S
I finally got a chance to “test” out Todd’s custom 1” thick rotor version of the 12.2” Wilwood BBK. This was at Watkins Glen, which is extremely hard on brakes. Todd’s bigger BBK worked flawless. A big improvement over the base Wilwood version with the 0.81” thick rotor. So nice to have brakes that you can count on to be consistent on a track like WGI:
Good to hear things worked out as planned!
