Suspension linear spring kw v2
Old Nov 27, 2017 | 06:27 AM
billy7986's Avatar
billy7986
linear spring kw v2
linear Springs kw
Hi I’ve just fitted some hypercoil linear spring 450lb all round to my kw v2 all fitted fine, just the ride hight on the front is a little high the front springs are 7inch and rears are 6inch. I’ve wound the front right down and the rears are half the way down. Would it be ok to swap the front spring to the rear and rear to the front help much appreciate
Old Nov 29, 2017 | 05:02 PM
gowest's Avatar
gowest
yes, you can, not a problem at all, though I do think your spring rates are to high for unmodified KW's. I'd probably want to limit V2's to at most 350 lb/in.
Old Nov 29, 2017 | 06:08 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
yah, heck I run 6" on both ends of my v3's (8kg front 9kg rear) with helper springs
Old Nov 30, 2017 | 12:24 AM
billy7986's Avatar
billy7986
If the spring rates are a bit bight what faults will i see. Also are the v2 shocks the same as the v3? Thanks for reply’s bill
Old Nov 30, 2017 | 04:32 AM
MrBlah's Avatar
MrBlah
I dunno, I run springs way higher than the v3 came with and I do not see ill effects. The spring holds the car up and resists some compression, the shock's only job is to slow change. The v2 are single adjustable rebound low speed. V3 are double and can adjust low speed compression and rebound separately.
both my damper adjusters are not maxxed out, I started at max damping I figured the springs would overpower the shock damping but I was wrong, it was too much even with the stiff springs I had to back out the damping on every setting both ends of the car
Old Nov 30, 2017 | 06:23 AM
billy7986's Avatar
billy7986
I’ll just give them a try see how I get on them I just got a email back from kw they said the 450lb spring will be fine for the v2 thanks for the reply
Old Nov 30, 2017 | 08:36 AM
billy7986's Avatar
billy7986
Aw I should just give it a try and see how I get on thanks for the replys I got a email of kw and they said the 450lb spring rate are fine on the v2
Old Dec 1, 2017 | 04:23 AM
billy7986's Avatar
billy7986
Thanks for reply I think I’m going give it a try and see how I get on. I spoke to kw and they said 450lb will be fine to run.
Old Dec 1, 2017 | 04:33 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Suggest you change your user name, the spammers are going to love you. Send me a PM with three choices and I can get the wheels moving.
