Navigation & Audio BS from the dealer
Old Nov 22, 2002 | 11:47 AM
kneedrachen's Avatar
kneedrachen
okay gang need some help here. i picked up my MC back in july and they could not find the card for the radio code. I am going to be doing some work this weekend on the car that requires completely disconnecting the battery. however, i have no radio code. my last car (VW jetta) requires you to enter the code each time the battery is disconnected or the radio is removed. Is it the same thing with the MC? i went to the dealership yesterday to have them pop the head unit to get the code for me but they refused stating "you dont need the code unless the radio gets taken out, the battery has nothing to do with it". is this true or am i getting lied to (again) by this dealer?
alex
Old Nov 22, 2002 | 12:17 PM
ssimms's Avatar
ssimms
The dealer should (for free) pull your head unit, decipher the serial number on the back of the radio and enter it into their factory computer which should in a matter of 3-10 minutes return your radio code information. BMW has done this for me since at least 1988.
Old Nov 22, 2002 | 12:18 PM
ssimms's Avatar
ssimms
By the way, you are correct anytime you disconnect the battery the radio will display CODE and you must enter it in order for it to work again. Your dealer is not very sophistated.
Old Nov 22, 2002 | 12:19 PM
ssimms's Avatar
ssimms
sophisticated is the word. Sorry
Old Nov 22, 2002 | 12:32 PM
minimotorin's Avatar
minimotorin
Hey guys, I disconected my battery to install the Rally Lights and I did not have any problems with the Radio, it worked as soon as power was restored.
Old Nov 22, 2002 | 12:33 PM
DennisJ's Avatar
DennisJ
Took A quick look at my Mini file (paper I received upon purchase) and noted a little slip of paper with the word RADSCHRAUBENSICHERUNGSCODE followed by a number. This little slip would be easy to lose, or misplace. My seventh grade German class was a few years ago, but I am guessing this is the radio code. It would be good to know the exact parameters of when and how this code needs to used. The radio owners manual is not of much help. I would guess that when the battery is dis-connected, the radio will ask for code input before functioning. Always a good idea to disconnect the battery when performing any 'beneath the bonnet' work, so this would be something good to know. Needed only when the radio is removed????
Old Nov 22, 2002 | 12:35 PM
minimotorin
Just so you know, I disconected the battery and reconnected it at least 10 different times while working on my Rally lights. It never asked for a code, nor did I lose the radio presets.
Old Nov 22, 2002 | 12:41 PM
ssimms's Avatar
ssimms
Having not disconnected the battery yet I stand corrected and in AHHHH of these two gentlemen. I am not worthy.
Old Nov 29, 2002 | 07:16 AM
minikai's Avatar
minikai
Hi DennisJ,
RADSCHRAUBENSICHERUNGSCODE = code for the security nut/bolt from your wheels.
minikai
Old Nov 29, 2002 | 07:23 AM
2minis's Avatar
2minis
>>Hi DennisJ,
>>minikai
I don't think my nuts came with a security code...
Old Nov 29, 2002 | 07:34 AM
minikai's Avatar
minikai
>>>>Hi DennisJ,
>>>>minikai
Old Dec 10, 2002 | 11:00 AM
wwwebb's Avatar
wwwebb
>>>>>>Hi DennisJ,
>>>>>>RADSCHRAUBENSICHERUNGSC ODE = code for the security nut/bolt from your wheels.
>>>>>>minikai
Its listed on the Mini's taint.
Old Dec 10, 2002 | 11:07 AM
Storer's Avatar
Storer
>>>>>>>>Hi DennisJ,
>>>>>>>>RADSCHRAUBENSICHER UNGSCODE = code for the security nut/bolt from your wheels.
>>>>>>>>minikai
I thought it was listed on the MINI's From-unda?
Old Nov 25, 2007 | 03:01 PM
COOPSTR's Avatar
COOPSTR
What if you take out the original radio and hook up another factory unit for the car and then turn the car on. Now you remove that radio and install the original radio.....will you need the code? Where is the MINI's taint? I thought the radio would display the code.
Old Nov 25, 2007 | 10:54 PM
daflake's Avatar
daflake
You kind of dug up an old thread here. (2002)
The MINI radio has no code to plug in. This was misinformation. When you plug the radio in, it talks to the IBus to make sure that it can be used. I have swapped a radio out with another from Ebay with no problems. (Both OEM).
Old Nov 26, 2007 | 07:43 AM
Paul!'s Avatar
Paul!
As said above, there's no code. I've done exactly as you described, and had no issues.
-Paul!
Old Nov 26, 2007 | 08:04 AM
COOPSTR's Avatar
COOPSTR
Bench test mode
I can confirm the same thing as to swapping out the head units. My new goal is to get the unit to the bench test mode. My understanding is that this can be done by changing from the Bus mode to the CODE mode.
elverado
Jan 18, 2022 02:51 AM
daidaibi
Mar 21, 2016 08:25 AM
hockeydad51
Oct 9, 2015 01:51 PM
PSU 98
Sep 11, 2015 11:20 AM
LowerKlass
Sep 10, 2015 05:59 PM
