R50/53 Removing front fenders
Old Nov 2, 2017 | 12:41 PM
RedAggie03's Avatar
RedAggie03
Can you get the front fenders off without removing the side skirts? Or is there a trick to getting to that lower bolt?
Old Nov 3, 2017 | 03:20 AM
N2MINI's Avatar
N2MINI
The Fender or the A-Panel. The Fender doesn't touch the side skirt so I assume your talking about the A-Panel, and best I remember you will need to atleast get the front par of the skirt loose enough to get that bottom bolt out..
Old Nov 3, 2017 | 10:13 AM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
sIf you're having trouble pulling the fender clips out, sometimes a small set of needlenose/snap ring pliers are nice to hold the outer section in place while you unscrew the center screw with a philips. Good luck!!
Old Nov 6, 2017 | 08:45 AM
RedAggie03's Avatar
RedAggie03
Yeah, I'm talking about the A-Panel. That bottom bolt is a beeotch.
Old Nov 6, 2017 | 09:03 AM
https://www.northamericanmotoring.co...el-arches.html
These ones? The forward ones on the hood.
Old Nov 6, 2017 | 11:14 AM
N2MINI's Avatar
N2MINI
He is talking about bolt No. 2 in here I think. That area slides behind the front part of the side skirt
https://www.realoem.com/bmw/enUS/sho...diagId=41_1373
Old Nov 7, 2017 | 02:07 PM
51131505864 51131505865 that are in my link above don't have a bolt, just a bunch of clips.
Old Nov 8, 2017 | 07:04 AM
RedAggie03's Avatar
RedAggie03
Yes, I'm referring to #2 in the diagram. Not the wheel arch trim.
Old Nov 8, 2017 | 07:07 AM
Ok, yea those things have clips which you can get with needle nose pillar on the back side. Check out my link above for pics. Its easier to remove the back portion of the fender liner( to that quarter panel) then go up and in to push them out.
