R56 wheelchair lift
Old Oct 21, 2017 | 11:31 AM
Chili Pirate's Avatar
Chili Pirate
wheelchair lift
Anyone put a wheelchair lift on your Mini.
Old Oct 23, 2017 | 12:59 AM
Shotgun_banjo's Avatar
Shotgun_banjo
You mean the lift that you put on the back using a tow hook receiver? You better find a way first to get a hitch in a mini then worry about the wheelchair lift. I have seen some aftermarket hitch but you will lose the rear fogs. If you do end up getting one then this won't be a problem for you.
Old Oct 25, 2017 | 12:10 AM
Chili Pirate
I saw a U-Tube video of a Bruno Type lifter installed in a VW GTI that was used to lift a scooter and put it inside. The lifter was mounted in the trunk area. I have seen the hitch you are talking about, but you have to dismantle the lifting unit. I am wondering if anybody has tried the inside set-up. Thanks for your reply...Bill
Old Oct 25, 2017 | 03:36 AM
KCLARK's Avatar
KCLARK
Just like shotgun said, you'll need to get the appropriate class hitch installed on your car first to ensure its compatible with the weight class.
I see they pretty pricey but $2399 can get you this one
http://www.americanwheelchairs.com/specliftal600.shtml
