SMF (Street Modified FWD) Hoosiers 225/40R17 FITS......
Old Oct 21, 2017 | 05:03 AM
jetsr6's Avatar
jetsr6
I have 2 weekends left and get a chance to use some Hoosiers. I was running Federal RSR's with pretty good success.
Attached Thumbnails Hoosiers 225/40R17 FITS......-img_3937.jpg   Hoosiers 225/40R17 FITS......-img_3948.jpg
Old Oct 21, 2017 | 05:06 AM
jetsr6's Avatar
jetsr6
These tires are 1.3 inches wider in each corner, so its going to be interesting.
Old Oct 21, 2017 | 06:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
what wheels and offset are you running.
I ruined a set of these as they cleared in the rear until under full load the rubbed on the trailing arm. So make sure you check the inside after you run.
Old Oct 21, 2017 | 07:30 PM
jetsr6's Avatar
jetsr6
There 17x8 45. I went for a scrub in and they did rub on arm. So I bought 4 3mm spacers. Already have a 8mm and using a 15mm up front. Yes I definitely will be checking after first run. I mite just go with the 8mm from the start.
Old Oct 23, 2017 | 02:59 AM
jetsr6's Avatar
jetsr6
2 wheelering it lol
Thanks I ended up using a 8mm and probably need a 10mm spacer for the rear. 6mm rubed after first run going at a moderate speed. Put on the 8mm and was a lot better with just a slight rub and finished out the day with that. No rubbing on the outside. Tires stuck very well.
Old Oct 23, 2017 | 06:52 AM
Burglar's Avatar
Burglar
So... they look a little stickier than the Federals, huh?
Old Oct 23, 2017 | 07:08 AM
jetsr6's Avatar
jetsr6
as soon as I let the clutch out to take off I knew that they were stickier LOL
Old Oct 23, 2017 | 07:16 AM
Burglar's Avatar
Burglar
I still can't get over how much faster your car is than mine. Makes me want to run STU soooooo bad.
Old Oct 23, 2017 | 07:40 AM
MiniMoic's Avatar
MiniMoic
What hoosiers are those? and rims?
Old Oct 23, 2017 | 07:47 AM
Burglar's Avatar
Burglar
Looks like 225/40-17 Hoosier A7 on 17x8 ET45 with a 15mm front and 8mm rear spacer if I follow the thread correctly.
Old Oct 23, 2017 | 08:58 AM
jetsr6's Avatar
jetsr6
Oh yea, 20-22 psi is a lot of fun!!!! I have a head that I will be able to up the rpm limits and just need to get som bottom end stuff to finish it up. 8,000rpms will be 73Mph 2nd gear.
Old Oct 23, 2017 | 09:48 AM
MiniMoic's Avatar
MiniMoic
Yeah, right. Just curious as I havent find 17x8 wheels that easy. What brand are they?
Old Oct 23, 2017 | 09:55 AM
Burglar's Avatar
Burglar
tire rack has a tool that lets you sort wheels by width. They list 4 different 17x8 ET35 & ET45 starting at $95/ea.
Old Oct 23, 2017 | 12:20 PM
jetsr6's Avatar
jetsr6
Konig hypergram 16lbs 17x8
Old Oct 23, 2017 | 12:37 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
what are you running for cambers?
Old Oct 23, 2017 | 01:12 PM
jetsr6's Avatar
jetsr6
3 up front and 2.2 rear 23mm rear swaybar on stiffest setting
Old Oct 23, 2017 | 04:22 PM
jetsr6's Avatar
jetsr6
Here we go, got the results.
Old Oct 26, 2017 | 04:40 AM
MiniMoic's Avatar
MiniMoic
Excelent!
Old Nov 7, 2017 | 10:09 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
what tires were you on before, and did it drop you in raw enough to justify the price?
I still have not decided what I will run next year, STX on rival S 1.5 225/45 or SMF with the track car on slicks, same hoosiers you got are in the shopping cart, costs about twice as much to run the purple crack
Old Nov 7, 2017 | 10:53 AM
jetsr6's Avatar
jetsr6
Well if I compare my time against Danny Kao in a 2017 Civic type r. I gained 1.5 sec. But that was 6 weeks apart from running with him. Plus I got better in that time too. This is my first year autocrossing. So I’m still learning.
There’s another guy in SMF class I beat him by 1.4 sec a month and half ago and last time I got him by 3.5 sec. So I definitely improved and the Hoosiers help. How much not sure?
The last event that I used the Federal RSR’s I ended up 3rd fastest raw time out of 67.
All my runs are here. I tried too make them entertaining.
https://www.youtube.com/user/jetsr6
Old Nov 7, 2017 | 11:13 AM
MrBlah's Avatar
MrBlah
so you think all the tire swapping at the event is worth it?
Old Nov 7, 2017 | 11:19 AM
jetsr6's Avatar
jetsr6
End of next year I’ll know. Just wanted to do everything I can with the class I’m in. If I would start over I would buy a brand new Car and run the stock class. I jumped into this head first lol. I just lucked out at being halfway decent. Probably not the answer your looking for.
Old Nov 7, 2017 | 11:33 AM
MrBlah's Avatar
MrBlah
this year i did stx with my coworker and it was fun I took the class for the year, but next year he moves to STH so I'm left wondering what class to run
Old Nov 7, 2017 | 11:48 AM
jetsr6's Avatar
jetsr6
I’m stuck in th middle of 3 Regions. 2 of them have 8-11 SMF cars and my closest has none. The smf cars I run against don’t make the power that I do. One of them asked me about buying a Mini for next year. Lol I told him I would help him. He was running a ford contour SVT.
Old Nov 7, 2017 | 12:30 PM
MrBlah's Avatar
MrBlah
here there's some tricked out civics that show up, mini wont touch those things, the are not even street cars anymore one of them grids with a generator and fan to cool the thing off.
They need to raise the minimum weight for SMF so newer fwd cars will bother showing up at the nationals
