Suspension IE adjustable or fixed with TSW springs?
Old Sep 16, 2017 | 06:40 PM
mationato's Avatar
mationato
I'm looking into getting KONI yellow shocks with TSW springs and I'm wondering what kind of camber plates to get. Will the IE fixed camber plates be too much and cause too much wear for a spirited DD with occasional track day / autocross? Otherwise I'll go with the adjustable camber plates, but I want to make sure that the fixed ones won't fit my needs before getting adjustable ones that might cause additional points of failure.
Old Sep 18, 2017 | 10:05 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I have Vorshlag camber plates up front and adjustable rear control arms, I am set to -2 degrees all around and don't have any uneven tire wear. The IE fixed plates are less than that, I don't think you'll see any problems.
Old Sep 24, 2017 | 07:30 AM
bcriverjunky's Avatar
bcriverjunky
Note that IE fixed plates will increase ride height.
Old Sep 24, 2017 | 01:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We only recommend using adjustable camber plates with our TSW springs. Going fixed will end up with too much camber and could be different side to side.
The Vorshlags are the best
https://www.waymotorworks.com/vorshl...er-plates.html
Otherwise I'd go with the Eibach
https://www.waymotorworks.com/eibach...0-r52-r53.html
Old Sep 25, 2017 | 05:00 PM
mbwicz's Avatar
mbwicz
I would listen to Way's recommendation. I ran IE fixed plates with yellows and TSW springs for over 50k miles. I had about -1.5 front camber, and -2.0 in the rear. I had even tire wear, and this was my daily.
The IE fixed raise the front of the car about 1/4", because of the extra plate that is used to get the extra camber.
I did have a front strut loosen up, this took out the strut and the mount. I blame myself for this, it wasn't anything with the components. It just sucks it was on the way to my track day at The Glen.
Have fun,
Mike
