misfire codes enlightenment needed
Old Sep 11, 2017 | 04:15 PM
J Free's Avatar
J Free
Could someone help me out with where to go from here. This is pulled from Carly. This misfire happens occasionally at start up. It will run fine after a few seconds. Thinking maybe plugs?
Motor Control:
Engine / Motor
Misfire, a plurality of cylinders: injection is switched off Code: 002781
Misfire, cylinder 4: Injection is switched off Code: 002779
Misfire, cylinder 2 injection is switched off Code: 00277D
Misfire, a plurality of cylinders: injection is switched off Code: 002783
Misfire, cylinder 4: Injection is switched off Code: 00277B
Misfire, cylinder 2 injection is switched off Code: 00277F
Old Sep 12, 2017 | 09:09 AM
MiniToBe's Avatar
MiniToBe
year and mileage?
Old Sep 12, 2017 | 12:37 PM
J Free's Avatar
J Free
Sorry, that would help. '09 JCW with 85K. I just walnut blasted the valves about 5K ago. After initial startup it runs totally fine.
Old Sep 12, 2017 | 12:57 PM
MiniToBe's Avatar
MiniToBe
i'm not a big fan of walnut blasting because if not cleaned right, it can cause some issues...can you inspect the injectors, and plugs. make sure sure they're tight.
Old Sep 12, 2017 | 03:10 PM
J Free's Avatar
J Free
It ran fantastic for months after I cleaned. Assuming you mean fuel injectors/plugs? Is there a way to do that without ripping everything out to get at them?
Old Sep 13, 2017 | 05:16 AM
MiniToBe's Avatar
MiniToBe
you could probably squeeze your hand after you take out the diverter and the vent valve...or run injector cleaner for now since you dont have a check engine light.
Old Sep 13, 2017 | 07:36 AM
J Free's Avatar
J Free
I'll try cleaner first. I did order some spark plugs, it's close to due by their schedule anyway. Thanks
Old Sep 17, 2017 | 07:31 AM
J Free's Avatar
J Free
Well, tried cleaner, new plugs. The old ones did look done. Same issue, same codes. Rough start, but then runs great. Odd that it's the same 2 cylinders.
Old Sep 17, 2017 | 07:39 AM
MiniToBe's Avatar
MiniToBe
Hummm...i think it is time to get back to the basics and go from there.
We know you have spark. Check the compression (wet and dry).
In my case i one had a leaking injector and didnt even have codes...looking through the hole, the cylinder was flooded...replaced and was good to go.
So check compression to make sure we have the right ingredient for a healthy ignition.
Old Sep 17, 2017 | 08:48 AM
J Free's Avatar
J Free
Pardon my ignorance, but wet and dry? Is a compression tester a rentable tool, maybe autozone?
Leaky injector is an interesting thought, maybe 2? Could explain a rough start that smooths once excess fuel burns?
Maybe pull plugs and look inside for petrol first?
Old Sep 17, 2017 | 04:58 PM
MiniToBe's Avatar
MiniToBe
Wet is when you add some oil through the spark plug hole to better seal the rings. Dry is the without oil.
Compression tool is cheap. Buy one from harborfrieght. Not sure if autozone rents it out. Maybe.
Old Sep 17, 2017 | 06:17 PM
J Free's Avatar
J Free
gotcha-thanks again
Old Sep 21, 2017 | 06:31 AM
J Free's Avatar
J Free
Unfortunately I haven't been able to get into this yet, but it went to reduced power mode this am. I pulled the codes and it was all the same, plus this. Maybe injectors 4/2 bad? Does this help?
Cylinder injection shutdown: Low pressure in the high pressure system
Code: 002880
Old Sep 21, 2017 | 06:34 AM
MiniToBe's Avatar
MiniToBe
sometimes a failing HPFP is the culprit and it is a known issue. check with the dealer if it still covered under factory warranty or something. can you get a live data reading on the fuel pressure?
Old Sep 21, 2017 | 06:57 AM
J Free's Avatar
J Free
Ouch, hope not. I have the Carly app, I think it can read that real time. As far as things that may relate to fuel, looking at app I see:
Filtered rail pressure value (absolute pressure MPa)
Pressure before throttle (psi)
Target pressure high pressure system (MPa)
Old Sep 21, 2017 | 06:59 AM
MiniToBe's Avatar
MiniToBe
what are the numbers?
Old Sep 21, 2017 | 07:07 AM
J Free's Avatar
J Free
My girlfriends got the car at the moment, if she makes it back I'll take a reading this afternoon.
Thanks again btw.
Old Sep 21, 2017 | 07:09 AM
MiniToBe's Avatar
MiniToBe
no problem...if you see yourself coming down to philly, I can run my tools on it.
Old Sep 21, 2017 | 10:00 AM
J Free's Avatar
J Free
Here's what I got:
Filtered rail pressure value (absolute pressure MPa) 5.28
Pressure before throttle (psi) 14.02
Target pressure high pressure system (MPa) 5.41
Old Sep 21, 2017 | 10:02 AM
MiniToBe's Avatar
MiniToBe
Yup...that's low...it should be in the high 7MPa
Old Sep 21, 2017 | 10:04 AM
J Free's Avatar
J Free
That's at idle, it does go up a little if I raise the revs.
Old Sep 21, 2017 | 10:09 AM
MiniToBe's Avatar
MiniToBe
Normal to go up when you rev it...but it should be 7ish at idle.
Old Sep 21, 2017 | 10:12 AM
J Free's Avatar
J Free
So you thinking probably HPFP?
Old Sep 21, 2017 | 10:14 AM
MiniToBe's Avatar
MiniToBe
yes...
if you unplug it, what is would be the pressure?
Old Sep 21, 2017 | 03:38 PM
J Free's Avatar
J Free
It looks like the HPFP is covered 10 years/120K miles. I made an appointment to have the dealer check it out tomorrow, we'll see.
