R56 push button ignition
Old Sep 11, 2017 | 12:20 PM
pckrwnnb's Avatar
pckrwnnb
How does that ignition switch work?
If I get a replacement do I need a new key?
Is the eprom (antitheft stuff) on the key read there or is that passed/recognized by something else.
Can that be rebuilt or refurbished to get some more mileage out of it? I've only got 67k on my 09 mini s.
Old Sep 11, 2017 | 01:03 PM
MiniToBe's Avatar
MiniToBe
the push button start/stop module is plug and play. you can use your key fob with no issues.
did i understand your question correctly?
Old Sep 12, 2017 | 04:30 AM
pckrwnnb's Avatar
pckrwnnb
Yes, that's headed in the right direction.
Is there a way I can test the switch?
fyi - I have a hot battery (16mo old 13.9 v). Radio and door locks work. I don't see any bad fuses. No response when I plug/dock the fob. This just started out of the blue. Jiggling and swearing made no impact! <g>
I started removing dash components so I can get the switch out. I hate to spend money without confirming this will be the fix.
thank you for your help.
Old Sep 12, 2017 | 05:27 AM
MiniToBe's Avatar
MiniToBe
the fact that it doesnt let the car start or you have to jiggle it, is thee test... the module isnt expensive, it's worth the replacement.
Old Sep 12, 2017 | 05:46 AM
pckrwnnb's Avatar
pckrwnnb
ok, point taken.
thanks!
Old Sep 12, 2017 | 05:52 AM
MiniToBe's Avatar
MiniToBe
keep us updated
Old Sep 16, 2017 | 03:52 AM
pckrwnnb's Avatar
pckrwnnb
Well ****
$100 on a new switch. Car still wont start and my fob is now stuck in the new switch.
do you know where i can find a wiring diagram?
Old Sep 16, 2017 | 04:00 AM
MiniToBe's Avatar
MiniToBe
Disconnect the module and reconnect it again, that MIGHT help to reset or release the key. Can you post a short vid of what's happening. Where are you located?
Old Nov 13, 2017 | 03:19 AM
pckrwnnb's Avatar
pckrwnnb
Fixed
I gave up and took it to a shop. Turns out the key went bad.
First time i have ever seen that but they acted like it is not uncommon.
Happy to be on the road again.
Btw they got me replacement keys for 1/2 what i had paid ordering direct from the dealer.
Old Nov 13, 2017 | 05:46 AM
Glad you got it fixed. Most of the time the battery built-in can fail. Did you have the CA option also?
Old Nov 13, 2017 | 05:55 AM
bugeye1031's Avatar
bugeye1031
Moderator
Replacing keys is a common disucssion topic. Can you share the shop name or anything else about how to save money on new keys?
Old Nov 13, 2017 | 07:19 PM
mattiemo's Avatar
mattiemo
Too late to help your situation. Also may not have have been the cause of you problem. The key fob recharges in the ignition. The manual states to use spare key fobs regularly to prevent the battery from dying.
more of an FYI for other reading this thread.
Old Nov 14, 2017 | 11:14 AM
3lusive's Avatar
3lusive
For MINIs without Comfort Access, this is true.
For MINIs with Comfort Access, the fob has a removable battery.
