R56 Strut mounts for R56 vs. GP2 - different?
Old Sep 6, 2017 | 04:08 PM
R56devotion's Avatar
R56devotion
Is there any advantage or design difference with the GP2 front upper strut mount vs the standard ones? The catalog pictures are vague and the dealer parts department will only sell parts based on VIN.
The construction, dimensions, camber pin etc all appear the same in pictures. Perhaps just a different rubber material that changes how stiff the mount is?
Thanks for your ideas?
Old Sep 6, 2017 | 04:29 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I believe there is a camber for caster difference between the two. Of course, this is purely hypothesis based on the regular S having the same part on both left and right and the GP2 having different part numbers for left and right.
Old Sep 6, 2017 | 07:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
the mounts are the same.
The difference is that the GP had the strut towers cut to let the mounts move in and get more camber.
Old Sep 6, 2017 | 07:44 PM
R56devotion
2010 mcs
Thanks for the reply. My 2010 has slotted towers, in the sense that with the camber pin pulled from a stock mount I can gain camber when moving mount. Is this what you are referring to? The part numbers are also different, but that by itself doesn't clarify.
In your experience, does using the GP2 mount or others offer any improvement without going to camber plates. My IE fixed plates are making noise and I'm tired of fussing with them.
thanks
