When did the convertible turbo cars get "reliable"
Old Aug 24, 2017 | 08:53 AM
Subw00er's Avatar
Subw00er
I'm guessing the 2009 vert at least had issues... when did the turbo vert cars get a bit better? I'm trying to decide what year car to buy to avoid a lot of common issues. I'm also open to the supercharged later year cars, but they're harder to find.
Also, when can we expect to pay the big bills (over $500)? I know about the timing chain/death rattle - that seems to happen around 100K, right? But I saw one car with it done at 45K miles! I'm sure someone summarized this by year/cost somewhere, but I haven't found that yet. Thanks for any leads there.
Old Aug 24, 2017 | 08:55 AM
DneprDave's Avatar
DneprDave
Get a 2011 or newer car with the N18 engine. They sorted out the carbon build up problems and the timing chain problems on the later engines.
Old Aug 24, 2017 | 09:01 AM
MINIAC's Avatar
MINIAC
Low mileage 1st Gen MCS Convertible for sale ...
https://www.northamericanmotoring.co...ml#post4324712
Old Aug 24, 2017 | 10:26 AM
Subw00er's Avatar
Subw00er
Thanks, but has rebuilt title.. http://grace-motorcars.com/mini-list...-sidewalk.html
Old Aug 28, 2017 | 05:59 PM
cargusjoh's Avatar
cargusjoh
WAIT: The 2011 convertible still had N14 motor. 2012 is N18 for both convertible and JCW. And production at April 2012 -> (see driver door jam) has the Bosh fuel pump, revised head/ecu. A little later in '12 (not sure when) the metal water pump was added.
Old Aug 29, 2017 | 05:35 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
N18 is just as unreliable as the n14, they share almost all the same part numbers, including the timing chain & guides, and the stupid cam driven vac pump, those are what grenade the engines
the only parts I could find different on the part diagrams are the oil pump, the n18 uses a variable pump, the n14 does not
the n18 has all the same carbon buildup problems too
Old Aug 29, 2017 | 10:00 AM
MINIAC's Avatar
MINIAC
Not true ... N18 was introduced in the 2011 US model year for all non-JCW Cooper S models, and 2013 model year for JCW models.
Old Aug 31, 2017 | 05:58 AM
Yes the N14 JCW carried on till 2012, then the N18 JCW came out in 2013.
