R50/53 Hydraulic handbrake
Old Aug 22, 2017 | 06:00 AM
Mudhen's Avatar
Mudhen
Hydraulic handbrake
Anyone installed a hydraulic handbrake in an R53?
I recall reading that it would need to be a dual master cylinder setup...and bore size? .625? Or does that even really matter.
Before I start buying stuff was hoping someone had a recipe I could follow. I'm not smart enough to be a guinea pig.
Thanks!
Pat
Old Aug 27, 2017 | 01:41 PM
X757XVeritas's Avatar
X757XVeritas
Hydraulic handbrakes have a master cylinder on the handbrake assembly.
Why go to hydraulic, this is usually something rear wheel drive guys do to help initiate drifts?
Old Aug 28, 2017 | 04:33 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
little curious why you would want to do this
Old Aug 28, 2017 | 05:22 AM
Mudhen's Avatar
Mudhen
I realize that...that's why I'm questioning if I need the dual master setup and what bore size.
I'm looking at this one:
I need it for 2 reasons. One is that I've had to tighten mine 3x in the last year so it clearly wasn't designed for handbrake turns in the dirt when you have tires that give a lot of traction (not only RWD drift guys want to rotate their cars using the rear wheels).
The second reason is that my arm hits the side of the race seat before the handbrake fully engages.
I swear I read that we HAD to have the dual setup just can't recall where it was...
Pat
Old Mar 12, 2019 | 11:17 AM
MonzMini's Avatar
MonzMini
You're awesome!
Did you ever get an answer on this one? Im trying to do the hydraulic handbrake myself. Also wondering if it matters what rear brake system I have.
Old Mar 12, 2019 | 12:43 PM
Mudhen's Avatar
Mudhen
Didn't get an answer but have somewhat worked it out.
I ended up buying that one in the pic, with two .625 cylinders. Connected into the ABS box, ran two lines to the handbrake and then out to the rear wheels. Then I couldn't for the life of me bleed them...did every single trick that anyone on the Internet has ever recommended and nothing. It would almost work but would feel like it was jammed solid.
After about a year of messing with it off/on I called Murray Motorsports where I'd bought the gear and they put one of their people on and we worked through it. I love those guys and they once again amazed me with their support. After describing how it was behaving he guessed it was most likely bled and connected properly, so it may be 'effort' related and recommended going with a single cylinder setup. He said with dual cylinders, hard brake pads, and gravel tires I'd probably need a bigger lever [and bigger arms] than I have. :-)
So I bought a single one...was able to use one of my original .625 cylinders (the other one blew the piston out of the front of it during a rallyx, lol), and just capped one of the outlets from the ABS box and used the other. Then put in a 'T' on the output side to go to the brakes. It still requires more effort than I like...not sure what else I can do, possibly different size cylinder. Not sure.
And I can't go back to using my ABS now...but half the time I'd forget to plug the wheel speed sensor back in anyway...she's old school now. :-)
What are you putting it into?
Old Mar 12, 2019 | 12:54 PM
MonzMini's Avatar
MonzMini
Sweet!
I'm considering putting one in my r53 for time attack more for the bucket seat reach issues you addressed. Im in the middle of a build
Old Mar 15, 2019 | 09:54 AM
The IRP is only a single but are more narrow so if you dont have room in the center with what seat you have, it would have a better chance working. I like your set up, that off-road rally MINI looks awesome.
https://www.ecstuning.com/b-irp-_-in...-parts/v-mini/
Old May 20, 2019 | 08:58 AM
falconshadow's Avatar
falconshadow
Pat
Where did you get your foot plate for the driver's side? Very nice
Old May 20, 2019 | 09:05 AM
Mudhen's Avatar
Mudhen
Rennline Track Mats.
http://www.rennline.com/Track-Mat-MI...ductinfo/TM22/
Only problem was I hated to scratch them up. :-)
