R50/53 Dealer Installed Non-JCW parts?
Old Aug 19, 2017 | 04:07 PM
mcswrks's Avatar
mcswrks
Hi everyone, was looking at buying a used Mini Cooper S R53. Apparently when the car was purchased new, it had non JCW parts installed as part of some dealer package. Does anyone recognize this or have any familiarity? I have no idea what kind of ecu upgrade that was done. Any idea on the total amount of power the kit would add? Thanks-
Old Aug 19, 2017 | 04:28 PM
Whine not Walnuts's Avatar
Whine not Walnuts
I am familiar with Promini and Borla but not SSX. The JCW would have had 380 injectors and the head is a little different with a 210 HP rating. The dealer package above was not cheap and even without the head and injectors, the 15% pulley (JCW was around 12%) would add more boost. I would think the car would be up towards 200 HP as it was tuned.
Would think others will chime in.
Old Aug 19, 2017 | 11:00 PM
mcswrks's Avatar
mcswrks
Thanks. But I'm more curious as to if anyone else had experience with a dealer offering all this as package. Not sure if the Borla is street or race, or what kind of ECU tune. What brand of parts, etc.
Old Aug 20, 2017 | 11:01 AM
MINIAC's Avatar
MINIAC
When was the package installed?
The cold air intake by BMP Racing was one of the earliest ...
Back in the day Randy Webb was traveling the country installing reduction pulleys for $400 (pulley included).
Early tunes were offered by Shark Injector or Unichip.
Pretty pricey package for bolt ons
Old Aug 20, 2017 | 11:29 AM
mcswrks's Avatar
mcswrks
I'm basically buying the now, as long as it passes an inspection. I will be the third owner, and the second owner had all the original purchase documents-and it honestly looks like that package was installed at delivery to the initial buyer, similar to the dealer installed JCW kits, because it has all the salesman cards stapled on.
Old Aug 20, 2017 | 03:47 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It is rare, but some dealers back in the day would install aftermarket parts. I would agree that the tune if any on it is likely a shark injector tune. If so I would actually remove it as they were too aggressive on the timing. Otherwise the other parts are fine.
Old Aug 20, 2017 | 05:20 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Damn, SC pulley, CAI, Exhaust and tune over $4K installed ??
That's like $3K labor....
Old Aug 20, 2017 | 05:23 PM
-=gRaY rAvEn=-
Moderator
Shark Tune will run these engines lean....get it out for sure.
Old Aug 20, 2017 | 09:21 PM
mcswrks's Avatar
mcswrks
Not sure it is a shark tune for sure though. Will try calling the dealership Monday to find out more info. Car has 62k miles with no apparent problems but I haven't seen it; and am going to have it checked out by a local shop. Anything I should ask they look at other than the usual precheck? And should I be worried about that tune being on for that long?
Old Aug 21, 2017 | 04:06 AM
-=gRaY rAvEn=-
Moderator
Read thread, and dont skim read Post #9.
https://www.northamericanmotoring.co...xperience.html
Old Aug 21, 2017 | 08:49 AM
mcswrks's Avatar
mcswrks
Thanks. Yeah, still trying to find out anything I can about the ecu tune. Called Mini of Sterling, every department seemed to have room temperature IQ. Still have the questions, would the car be ok at 60k if it was running that tune (id get it retuned asap) or could that local shop tell what tune was in it? Appreciate all the help guys.
