Ignition Help?!!
Old Aug 4, 2017 | 11:34 AM
Lokiswrath's Avatar
Lokiswrath
Ignition Help?!!
Hello all,
I have a 2009 Clubman and when i insert my FOB key nothing happens the car doesnt seem to register that it is inserted, I have replaced the battery to the key and it still works when locking and unlocking doors etc just not for the ignition. Does anyone have any idea what the issue could be? I cant seem to find a shop anywhere near me that can find/fix the issue which i assumed was the actual ignition piece in the dash.
Any advice would be more then helpful
Thank you.
Also I will be more then happy to answer as many questions as needed or even upload a video of the issue if it helps! From what i have been told the ignition can only be replaced by a BMW/Mini place because it has to be reprogrammed even if its just the plastic piece.
Old Aug 4, 2017 | 11:44 AM
Lokiswrath's Avatar
Lokiswrath
I apologize just realized i posted in wrong subthread area. feel free to delete reposted in Mechanical issues.
Old Aug 4, 2017 | 09:23 PM
MiniToBe's Avatar
MiniToBe
The ignition on the second gen is electrical and needs no programming. My countryman did the same thing. When you set the key in the cradle, push it on an angle amd try to start the car. Try few times til you find the spot...
Where you located?
Old Aug 4, 2017 | 09:27 PM
Lokiswrath's Avatar
Lokiswrath
I have tried that. It used to work sometimes now nothing. I am in Jacksonville North Carolina. Someone said if i replace that plastic piece ill have to reprogram either the ignition or the key. not sure how accurate this is.
Old Aug 4, 2017 | 09:31 PM
MiniToBe's Avatar
MiniToBe
It probably completely dead...yeah just buy another one you'll be fine. No programming needed...check my posts for qualifications if you want.
Old Aug 4, 2017 | 09:34 PM
Lokiswrath's Avatar
Lokiswrath
ill check out Pelican Parts that seems to be the place to get mini stuff like that unless you have another recommendation?
Old Aug 4, 2017 | 09:38 PM
MiniToBe's Avatar
MiniToBe
Ebay should be fine and more economical. Buy used and working of course.
Old Aug 4, 2017 | 09:42 PM
Lokiswrath's Avatar
Lokiswrath
Ill look around see if i can find it. i assume a search of 2009 clubman ignition switch will work.
Old Aug 4, 2017 | 09:52 PM
MiniToBe's Avatar
MiniToBe
I believe any switch will work from 2007 to 2014 of 2nd gen whether it's base, S, auto, or manual.
Old Aug 4, 2017 | 10:17 PM
Lokiswrath's Avatar
Lokiswrath
alright ill take a look. i found one on Ebay but i will prob have ot call the shop thats selling it. I have questions about how they are selling it want to make sure i dont spend $100 and screw myself.
Old Aug 7, 2017 | 08:35 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are we talking about the ignition stop/start switch? If so, it's plug and play (no programming needed).
We have them here: http://www.pelicanparts.com/catalog/..._pg2.htm#item5
DIY for an R56 here, but gives you an idea: http://www.pelicanparts.com/techarti...eplacement.htm
888.280.7799 | 6am - 5pm PST
