R50/53 am i lowered?
Old Aug 3, 2017 | 04:16 AM
twilightprotege's Avatar
twilightprotege
am i lowered?
so i'm not sure if my r53 park lane is lowered or not. strange i know, but i'll explain. i've got 205/45/17's too on the s-lite wheels
the springs have no visible signs of part numbers on them as if they were after market jobs and they are what i assume is standard looking black.
however the height between the road and the top of the wheel arch isnt what i think it should be
so the fronts are 630mm, the rears are 635mm. i thought they should be 650 and 655mm?
and to possibly mix it up i'm in australia. does the aus model have lower springs to begin with? or is the 630/635 the standard height and the 650/655 i thought it should be just wrong info?
Old Aug 3, 2017 | 05:03 AM
Whine not Walnuts's Avatar
Whine not Walnuts
A picture is worth a thousand words. My friend had his car lowered, mine is a JCW sport that is 1/2" lower than the stock S. Whereas the 1/2" is hard to tell, a normal lowering is pushing over an inch and that is easy to see.
Old Aug 3, 2017 | 10:28 AM
Aspen's Avatar
Aspen
MINI had lots of springs. Std, S, Sport, GP. Difference between R52 and R53 and IIRC differences between auto and manual tranny.
You may have the factory Sport Suspension.
Old Aug 9, 2017 | 07:07 PM
twilightprotege
late reply, but here's a pic of the car/wheel gap. ignore the gutter rash (new to me car, will fix it when i get better tyres). car is a 2006 r53 park lane edition manual
Attached Thumbnails am i lowered?-img_20170809_082704.jpg   am i lowered?-img_20170809_082715.jpg   am i lowered?-img_20170809_082725.jpg
Old Aug 10, 2017 | 03:30 AM
Whine not Walnuts
It appears you have about 2 fingers between the top of the tire and the bottom of the black plastic trim. That looks close to my JCW that has 1/2" lowered springs.
And nice looking MINI.
Old Aug 10, 2017 | 04:51 AM
IQRaceworks's Avatar
IQRaceworks
That looks about the same height as my MINI...and it's not lowered. I'd say you have the stock coils on it.
Old Aug 10, 2017 | 05:47 AM
Aspen's Avatar
Aspen
Looking at pictures is not very accurate and it gets worse due to differences in tire sizes. You need to measure from the wheel arch to the ground or from the arch to hub centre and then compare that to somebody with stock or lowering springs.
Old Aug 10, 2017 | 03:56 PM
X757XVeritas's Avatar
X757XVeritas
Same size tires on mine. Height looks identical. I'm on stock suspension so id say no, you are not lowered at all.
