R50/53 Mini newbie looking for guidance
Old Jul 30, 2017 | 04:36 PM
SteveAshmore's Avatar
SteveAshmore
A couple days ago I was driving fine in my 2005 R53 with 86k miles. I turned a corner and saw a significant drop in power and my service engine soon light started flashing. I was able to get the car home. Once I got my scanner on it, it showed 2 codes P0303 and P0313. My buddy came over this morning and did a compression test and cylinder 3 had zero compression. Plugs and wires are brand new too. Am I screwed as far as the motor goes? Or is there another option? Any help is appreciated.
Old Jul 30, 2017 | 04:50 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Maybe the compression test was not done properly ? Especially lacking other symptoms leading up to this event.
Just for the heck of it, try this.
Open bonnet pop off the plug wire from number 3 post on the coil pack ( drivers side nearest fire wall ) Examine for rust/corrosion.
It is known for that....and it will only happen to that one coil pack post.
If present, clean out the wire connector best you can with a flat blade screw driver and using the green scrounge side of a sponge clean off the coil pack terminal. Should not use anything more abrasive than a green scrounge side of a sponge for this, so no sand paper please.
Reconnect the wire and see what happens.
Old Jul 30, 2017 | 05:25 PM
SteveAshmore
I used the sponge green side and cleaned it up but it still acts the same. My car sounds like a Subaru lol.
Old Jul 30, 2017 | 05:29 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Try a dollar bill test. Put a piece of soft paper behind the exhaust pipe. Start the car and if the paper flutters, you have a burnt valve. A Mini Misfire code is a burnt valve in allot of cases. Good valves all around will make the paper push out like a flag on a windy day.
The tractor sound is also a burnt valve sign.
Old Jul 30, 2017 | 06:08 PM
SteveAshmore
What do you mean by paper fluttering? I'm confused
Old Jul 30, 2017 | 06:21 PM
Whine not Walnuts
Watch the video below.
Old Jul 30, 2017 | 06:43 PM
SteveAshmore
I don't understand how that tells you it has a burnt valve. Am I missing something? Lol
Old Jul 30, 2017 | 07:53 PM
ptiller's Avatar
ptiller
The paper is getting sucked back in due to the intake stroke 'pulling' through the exhaust.
Old Jul 31, 2017 | 03:30 AM
Whine not Walnuts
Means the valve is burnt and there is no "compression" in the cylinder so no air is pushed out.
Old Jul 31, 2017 | 03:29 PM
SteveAshmore
Will be doing leak down test this week too
Old Aug 2, 2017 | 07:06 PM
IQRaceworks's Avatar
IQRaceworks
Do a compression test again. What do you mean there you ZERO compression on cylinder number 3? I've never seen a cylinder with ZERO compression.....usually it's low, but not zero. Even with no rings on the piston you will see 10-30psi in the cylinder when cranking the motor over.....unless you have a stuck valve or some other major issue .
