Tire Size and Gas Mileage
Old Jul 23, 2017 | 11:22 AM
rphox2003's Avatar
rphox2003
Hi,
I finally took the plunge on my F56 and went from 175/65/15 to 195/55/16.
I've been using an app for the longest time to track mileage and was averaging around 15 kpl on the 15s. Depending on driving and traffic, I would get anywhere from 13 to 16 kpl.
Now, after 3 tanks on the 16s, I'm getting about 13.5 kpl.
Is this normal or should I wait for a larger sample?
Thanks.
Old Jul 23, 2017 | 02:12 PM
hsautocrosser's Avatar
hsautocrosser
Historically the best mileage reports from MINI owners come from those with 15" wheels.
And yes, you should have more than three fillups in a sample.
Old Jul 23, 2017 | 03:01 PM
elvis cole's Avatar
elvis cole
One factor of consumption is tire diameter. A larger diameter tire will cause your engine to turn fewer RPMs at a given speed which mean you go farther n a unit of fuel....a smaller diameter tire turn faster meaning you buzz your motor faster at the same given speed. More engine RPM = poorer mileage. Your wheel size got bigger but you went to a lower profile tire. You can find a chart on line that will tell you if you gained or lost overall diameter.
Old Jul 23, 2017 | 03:35 PM
isamin's Avatar
isamin
Taller tire with higher pressure will yield better mileage.
Remember, the fuel you save ,I waste.
Optimum results if car remains parked.
ISAMIN
Old Jul 23, 2017 | 05:37 PM
gjxj's Avatar
gjxj
in this case the big change is the width. Wider = more rolling resistance.
Old Jul 23, 2017 | 08:53 PM
rphox2003's Avatar
rphox2003
Thanks for all the input.
Old Jul 23, 2017 | 09:28 PM
Fly'n Brick's Avatar
Fly'n Brick
There are several tire size to odometer variable calculators available on line. Here's just one.
https://tiresize.com/calculator/
And, if you need more conversion problem solving, here's a whole list of automotive stuff.
http://www.csgnetwork.com/automotiveconverters.html
Old Jul 27, 2017 | 06:36 PM
'05Train's Avatar
'05Train
A taller tire will effectively decrease your final drive ratio which will aid with mileage, but....
- If it's heavier, it will decrease mileage, and harm your going, stopping, and turning.
- If it's wider, it will decrease mileage due to frictional and aerodynamic losses. It's probably also heavier.
I just went to a slightly taller, wider tire, on a lighter wheel. I'm hoping the additional height, width, and drag are offset by the lighter weight.
