Navigation & Audio Recoding Head Unit To car
Old Jul 23, 2017 | 10:45 AM
JohnnyZenith's Avatar
JohnnyZenith
Hello, I have a 2007 R55 Cooper S Clubman. I took it to BMW recently as I have no gongs, can't use my Bluetooth, microphone etc or aux or USB port. The guy who had my car before swapped the stereos out, so my car has another minis head unit coded to that car. I have radio and DAB. BMW can't or won't reset the head unit. How is this achievable? I'm at my wits end. I'm in the UK.
Old Jul 25, 2017 | 10:57 AM
MiniToBe's Avatar
MiniToBe
Verify that you actually have these options. use bimmer.work the units should be plug and play. Make sure you still have the blue tooth module under the left seat. try NOT to disconnect the airback (yellow plug) from the seat.
Old Jul 25, 2017 | 07:44 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Moved you to Navigation & Audio, hope you'll get more eyeballs here.
Old Jul 27, 2017 | 04:09 AM
JohnnyZenith
Thank you for moving the thread.
Old Jul 27, 2017 | 04:14 AM
JohnnyZenith
Thanks for the reply. Yes I definitely have Bluetooth on board. BMW told me it's an issue of coding. Unfortunately they can't or won't wipe/reset the coding the stereo has to another car. This is all too difficult for me.
Old Jul 27, 2017 | 04:22 AM
MiniToBe's Avatar
MiniToBe
the only thing i can think of is you buy another head unit with the same options and see if it works. make sure the item is returnable if anything...btw, does it have the navi?
Old Jul 31, 2017 | 09:22 AM
alexs3d2's Avatar
alexs3d2
If it is a coding issue you can do it with NCSExpert and D-CAN cable. BMW Service Centres will only use standard dealer-level software, which may not allow them to code a non-blank unit even if they had all the willingness to do so.
NCSExpert and WinKFP are factory/development level, so will allow you to do almost anything.
Old Jul 31, 2017 | 02:03 PM
JohnnyZenith
Thanks. That is really good information. I just need to find someone who can do it. We will see.
