R58 Hood scoop
Old Jul 21, 2017 | 02:21 PM
LostbutFound's Avatar
LostbutFound
Hood scoop
Just bought my first Mini Cooper S Coupe and when I got it home I noticed the hood scoop is not functional. I thought I read that it was in a S. Any info would be appreciated.
Got this one
Old Jul 21, 2017 | 03:42 PM
Capt_bj's Avatar
Capt_bj
purely cosmetic after the GEN1
you're new .... GEN1 = the first MINI body style and the scoop actually feeds the intercooler .... 2002 thru 2006 <for the hard top> 2007 begins GEN2 ... the body and MOTOR changes ... that scoop is just an ornament
Old Jul 22, 2017 | 07:42 AM
LostbutFound
Ok I must've crossed some wires while reading and trying to learn about the Mini's. Greatly appreciate your response.
Old Jul 22, 2017 | 06:16 PM
spiney's Avatar
spiney
You can get open grilles from a couple of vendors that may possibly help keep the scoop from warping due to underbonnet heat, but usually it's non functional as said above.
Old Jul 24, 2017 | 12:31 PM
TheBigNewt's Avatar
TheBigNewt
Fake scoop!
Old Jul 24, 2017 | 01:01 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
All the above are correct, from a certain point of view. It all depends on your definition of "Functional". The Gen 2 scoop is functional, in that it allows some air flow into the engine bay. However, it is non-functional compared to the 1st Gen cars, in which the scoop directly supplied airflow to the intercooler.
If you want a truly non-functional scoop, go check out the 3rd Gen cars... That scoop doesn't even feed air to the engine bay, and the hood is even solid under it!
Old Jul 25, 2017 | 02:19 PM
Capt_bj's Avatar
Capt_bj
my GEN2 scoop inserts have had a couple of tiny holes in them ..... not much air flow thru that to be considered functional. When Spousal unit gets home with her R59 I'll take a picture to explain the point ...
In my 2002 the scoop was 'open' and actually the dealer recommended putting in a screen to prevent debris from getting into the intercooler coils. (I was a very early buyer .... what Navy folks would call a 'plankowner')
update: scoop insert on our R59 S is about 50% open (cut out sections)
Old Aug 3, 2017 | 06:01 AM
scf's Avatar
scf
You can remove the scoop "grille" by just removing a couple of allenhead screws. Doing this opens it up for adding a CAI with an air scoop.
Old Aug 3, 2017 | 07:42 AM
DneprDave's Avatar
DneprDave
I took the grill out of the scoop on my R55. I was all ready to make a metal screen replacement but I thought it looked good without anything in the hole. It's been a few years since I did that and I haven't seen any increase of dirt or bugs on the engine.
Old Aug 3, 2017 | 09:57 AM
mashby's Avatar
mashby
And you can make it functional if you want to. https://www.waymotorworks.com/ddmwor...ke-system.html
Old Aug 3, 2017 | 09:58 AM
scf's Avatar
scf
And I happen to have one of those for sale too!!
Old Aug 3, 2017 | 07:15 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Good looking Coupe. Welcome aboard.
Old Aug 3, 2017 | 07:53 PM
LostbutFound
Functional scoop options
Thanks for the link. I didn't notice that it had 2 sources for fresh air the first time I looked at it. I find that interesting. It seems the problem with most of this type of fresh air induction is the loss of torque at take off. The duel feed may reduce or eliminate that problem.
Old Aug 3, 2017 | 08:02 PM
LostbutFound
Thanks you. I have been following you and your new family member.
Old Aug 3, 2017 | 08:05 PM
LostbutFound
Scoop options
Did you notice any loss of torque or any other problems?
Old Aug 4, 2017 | 04:03 AM
scf's Avatar
scf
No, can't say that I did honestly. I've seen some posts regarding torque and a CAI, but doesn't make sense to me.
I bought another CAI for my CMS, just didn't see the sense on using only a portion of the DDMWorks RIS.
Old Aug 4, 2017 | 04:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I have an AEM intake with the hood scoop duct, and I saw no loss of torque when installed.
I've seen torque loss comments on the forum, too, and most of those comments came from N14 engine owners after installing one of the open style intake kits. I am of the belief that the N14 engine cars are more sensitive to intake torque loss than are the N18 engine cars.
Old Sep 14, 2017 | 08:47 PM
RYANR56's Avatar
RYANR56
I drilled about another 20 holes in mine It is open, and there still is some structure left. Just taped up all my paint. But I guess I could have taken it all the way out too
