Reduced Power Warning
Old Jul 18, 2017 | 01:43 PM
Christopher Jacob's Avatar
Christopher Jacob
Hey All,
I have recently come to own a 2008 Clubman S with ~117k miles on it. I had a couple of issues (leaky valve cover) that I have fixed and managed to clear and keep clear the CEL.
However, I still have a reduced power light (half filled engine icon) and seemingly no boost. (the care drives _ok_ but about what you would expect with no turbo) I pulled the supply hose on the turbo and everything in there seems to spin freely / not wobble.
I am not receiving any fault codes on my generic OBDII device. (although I have no access to a mini specific one)
Is it possible that a sensor (perhaps o2) is showing something as off and the car is killing the boost? Or is it more likely there isn't any vacuum (because of some leak I can't find) and so no boost?
Does anyone else have any ideas? I don't mind sinking a little money into it to try to get it going right, but at this point I feel like I would be throwing darts at a dartboard to guess, since I don't have any trouble codes to give me a clue as to where to start.
Thanks!
Chris
Old Jul 19, 2017 | 12:13 PM
Wildfield's Avatar
Wildfield
I encountered a similar situation. I took it to the dealer, since I have an extended warranty. They diagnosed as a faulty vanos solenoid. I believe this cuts your power because the lack of a functioning vanos solenoid keeps the engine timing from adjusting to higher RPM's...although I could be wrong on this point.
Old Jul 19, 2017 | 01:02 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Could be a whole bunch of things, but without the code no one can help you.
Old Jul 19, 2017 | 02:39 PM
Christopher Jacob
Yeah, I get that. It's not throwing any of the standard P codes that my (non-mini) reader can pull. So, not sure my options outside of a dealership or acquiring one of the mini/bmw readers.
That said, does anyone have any suggestions on which ones work best? Or maybe which ones work well enough, but don't cost as much as the best?
Old Jul 20, 2017 | 03:38 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I bought an OBD wife dongle from Amazon, and the Carly BMW app. I went with that app because it can read codes, OBD readiness, and perform coding.
If you were close by I would offer to help you out. Where are you located?
Old Jul 20, 2017 | 08:35 AM
Christopher Jacob
I am in Marylan. So... not all that close.
Old Jul 20, 2017 | 10:22 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
No problem, I tried.
Old Jul 27, 2017 | 12:56 PM
Wildfield's Avatar
Wildfield
Just curious if were able to figure out what caused the reduced power warning. Hope all is well now.
Old Aug 2, 2017 | 07:43 PM
Christopher Jacob
Not yet. Still working on it. I will update as soon as I figure something out.
